New APM 2.5 has pink foam...
Just got another APM 2.5 in the mail today. This one appears to have a piece of pink foam inside the case. My original APM 2.5 did not have this foam. Is this something new? Does it need to come out? If not, do I need a piece in my older APM 2.5?
Thanks!
  • Thanks for the replies. Is the foam something I can pick up at Radio Shack and cut myself?
    Ty,
    Are you referring to the piece of pink foam that comes with the APM 2.5 case? If so then yes that piece of foam is important, it should rest on top of the barometer.  Without it you could subject the barometer to wild changes in air-pressure as your attitude and speed changes, leading to some exciting moments especially when in any auto mode where the AP is attempting to maintain a specific altitude.
    If you received a case without the piece of adhesive backed pink foam I would contact 3DR for a replacement or find a suitable piece of foam yourself.
    Nathaniel ~KD2DEY
  • Admin
    @Ty,
    Yes, the pink antistatic foam is supposed to be in the case between the pwb and the top of the case. If you want to, you can put a piece of pink antistatic foam of the same dimensions in your APM2.5 case that does not have the pink foam. However, if you disassemble the case, just make sure that you get the reset switch plastic extension put back correctly and do not over tighten the case screws so that they do not strip out.
    TCIII
DIY Robocars via Twitter
Practice virtual race this Saturday; the real thing will be on Oct 3 https://www.meetup.com/DIYRobocars/
2 hours ago
2 hours ago
Derrick Davies liked lisa TDrones's profile
3 hours ago
Monday
RT @SahikaGenc: AWS DeepRacer & Hot Wheels Track https://youtu.be/4H0Ei07RdR4 via @YouTube
Sep 14
Sep 8
RT @davsca1: We are releasing the code of our Fisher Information Field, the first dedicated map for perception-aware planning that is >10x…
Sep 8
RT @SmallpixelCar: How this works: 1)object detection to find cones in single camera image, 30 frames/sec on @NVIDIAEmbedded Xavier. 2)comp…
Sep 8
RT @SmallpixelCar: Use two color cones to guide the robocar. No map needed, on onsite training needed. Just place the cones and it will fol…
Sep 7
Sep 7
RT @roboton_io: Great to see http://roboton.io running at 60fps on the cheapest #chromebook we could find! #edtech #robotics #educat…
Sep 3
RT @openmvcam: Crazy in-depth article about using the OpenMV Cam for Astrophotography: https://github.com/frank26080115/OpemMV-Astrophotography-Gear https://t.co/BPoK9QDEwS
Sep 3
RT @openmvcam: Hi folks, it's finally here! Our first draft of our Arduino Interface Library is out! It works over SoftwareSerial, Hardware…
Sep 3
RT @chr1sa: Please let them have an open API. This would be perfect for @DIYRobocars races https://twitter.com/NintendoAmerica/status/1301513099707658246
Sep 3
RT @SmallpixelCar: Lanenet pretty much used all my GPU power on @NVIDIAEmbedded Xavier since I optimized with tensorRT. I need to run anoth…
Sep 3
RT @LyftLevel5: Our @kaggle competition on Motion Prediction for Autonomous Vehicles is now live! Experiment with the largest-ever self-dri…
Aug 24
