Good evening all, I am new to building quads and would line some advice on a number of things.To start with I have acquired an octocopter frame withProp drive 28-30 900kv motors.Hobby King 30A ubec ESC.I have on order a new power distribution board and, FPV APM2.8 ArduPilot Mega External Compass Flight Controller +Ublox NEO-6M GPS Power Module RC149.The questions I would like to ask are,Would I require to re program the ESC's?What would be the recommended battery'sWhat would be a recommended prop size (looking at 10x5e)Also, what would be a recommended TX & RX system for an octo?Thank you in advance for any help
Would I require to re program the ESC's? They have something in the store which looks like a usb key to 3 wire connector, it's usually called an ESC flasher.
What would be the recommended battery's - Probably a 4Ah 4s, any brand is fine to start off, and later once you work out all the kinks, you can get a more expensive one.
What would be a recommended prop size (looking at 10x5e) - that's a good prop size.
Also, what would be a recommended TX & RX system for an octo? - The Taranis X9D is decent, really any system would work.
