Starting a new thread to show what I'm working on.  I'm building a new Octocopter of my own design.  The goal is to use it for Aerial Photography, lifting a mid-weight camera such as a Sony Nex5.  It will of course be using Arducopter for control.  ;)
I started off researching the various kits on the market, and starting getting analysis paralysis.  I looked at all the options such as Droidworx AD8, Cinestar, CarbonCore, and SteadiDrone.  But I just wasn't happy with the design on them, particularly for the price they ask.  Combined with the fact that I can be pretty frugal, and have a strong DIY ethic, I decided to just design my own.
The basis of the design relies on many of the Hobby King quadcopter parts.  I liked the design of the motor mounts, they are very professional looking, even compared to some of the high end machines.  And I liked that the boom mounts are blocks of aluminum instead of plastic.  Very rigid.  I also liked the look of the dome on their H.A.L. quad, but since they don't sell it seperately, I bought the whole kit, it's only $34, amazing!  I might end up using the rest of it someday, who knows?  So, I basically emptied out their stock of Talon parts, so if you need to fix your Talon quad and the parts are backordered... sorry!
Once that was settled, I set about designing the center frame.  My design required a few things, namely I want all the wiring hidden.  I don't want any spaghetti showing.  Particularly with the ESC's, while still allowing cooling airflow.  This required the center hub to be larger than is typical.  I then needed a smaller subframe to house the avionics.
You can see these plates below.  The larger one houses the HAL dome. You will notice the 3 blue anti-vibration grommets in the middle.  This is the APM1 pattern.  I did that just because.  Maybe I'll use an APM1 as a stand along gimbal controller.  The second plate had grommet mounting for an APM2.  The final plate is the top plate, and has bolt patterns for the Ublox GPS and the magnetometer.
This next photos shows the avionics frame built up with an APM2 mounted.  25mm aluminum standoffs are used. I don't like the plastic standoffs typically used.  They get loose, and lead to vibration.  They also break easily.  This structure ends up being quite rigid.
Here is the avionics frame mounted on top of the main frame.  Yes, the main frame is HUGE.  I actually don't see the point in having a tiny center frame, and then long arms.  This seems like it just leads to flex, and doesn't leave you with any real estate to mount your avionics.
This photo shows one of my design features.  I put some cutouts on the bottom frame for weight savings, and then made matching cutouts on the top frames.  This creates some nice conduits to run wires neatly.
Here it is with the HAL dome mounted and one of the Talon arm mounts bolted in.  I'm really happy with how stiff the assembly is already.
Here it is with one of the arms mounted.  These are the short 220mm arms, I also got some of the 320mm arms.  One may wonder how I'm going to get away with such short arms and 13" props....  Astute readers will know what I'm planning already. ;)
This last photo shows one of the ESC's in position. This is a Hobby King F-40A, it's somewhat larger than typical 20A units which is partially why the frame is so big.
That's it for now.  I had the plates cut out of aluminum to start with because it's cost effective.  If it all works out, I'll probably have it redone in carbon fiber plate for the weight savings.  I was a little uncertain about the weight, but it looks like the frame will come in at 1070g all in aluminum.  That's about 300g heavier than a Droidworx AD8, but not too bad. It will drop about 1-200g if redone in CF.
Hey, thanks! Ill be in touch if so!  Jb
Maiden flight is done!  Wahoo!
...some issues with compass wandering, but I'm sure I'll sort that out.
Very pleased.  Thanks for so many of your help getting this far :)
Awesome job, Jake! Congrats.
Congrats.......nice to see it fly
   I really like what you have done.
Good job
Anything new on this Octo. I'm actually getting around to ordering parts to complete the project. I have all the cf parts that I ordered from Rob a year ago :(. Are there any changes I should make from the original design in the way of motors, esc's, props, motor mounts, booms, boom lengths, etc. Any guidance would be appreciated.
I'm still flying mine and the only issues I have are how the booms are held to the center piece. You should replace the screw that holds the boom to the center piece with a ss screw like Rob supplied. I ordered some extras from the same place he got his. If you try to torque down on the ones that come from HK, they will break. I also have used epoxy on a few of them because they just wouldn't stay put. Before flying I always grab each motor and try to twist it with a little force just to make sure it's not loose. The motor mounts also can't take any sort of light crash like the props getting bumped on the ground in case of a rough landing. They bend too easily. They will bend before a prop usually will break.
Steve, glad you and others are still liking it.  I just ready your post about the gap between the motor mounts and the top plate.  I think that the Talon quads are built the same way, no?  In any case, even if the motor mount was touching the top plate, it would really only be rubbing it, it would not give much support at all.  You'd actually end up wearing both plates.
That's largely the reason I abandoned the design.  The Talon motor mounts and boom mounts are just not very good.
FYI, I have one set of aluminum plates left for $50 if anybody wants them.
If you guys like this design, I really should market my H8.  It's SOO much better.
Thanks for reminding me about that. The solution I can up with was just just cut down the aluminum spacers on the boom mounts (you said motor mount but i think you meant boom mount) and that really makes it clamp down better. They are just about 1-2mm too long. I just took a dremel to it.
The other problem is the side screw being too weak from the Talon kit. That was easily solved by using the ss screws you use in the kit. On a couple I had to use some epoxy for extra assurance. Really the problem is the metal is too soft for both the motor and boom mounts but if you never had more than a hard landing then it's ok. I've rolled mine a couple of times because I have very little flat landing space and forgot to plug in all 4 batteries sometimes in the beginning. It actually takes off with 1 3300x4S but you pretty much kill the life span of that battery in the process and have maybe a 4 minute flight ;-)
For a long time I haven't had any crashes but I'm not flying it as much as my others because I'm having trouble with the gimbal not wobbling back and forth and that was the main reason I built it.
Would love to see your H8. Start a thread if you haven't already! I'm sure it's a much improved design over this one.
Hi Rob,
Anyway you can throw up some info on your H8 before I order any more stuff?
