Hi All,
Is is possible to design a UAV that uses its entire body as a rotor during take-off ?
Concept :
In this UAV vertical take-off does not require an external rotor or a thrust/weight ratio greater than one. When this UAV reaches a safe altitude, it transitions to horizontal flight.When this UAV reaches a safe altitude, it transitions to horizontal flight.
Landing is the same sequence in reverse. The retractable landing gear ends in a simple rubber ball. When the engines are stopped, a dolly
supports the aircraft on the ground.
I would sincerely appreciate any feedback that I get about this concept .
Debo
Attached : Video of this concept
Hey,
something similar has been done:
http://www.youtube.com/watch?v=u23Hqq8QbeE&feature=player_embedded
phil
Hi Philippe,
Sincerely Appreciate your valuable insight.
Debo
Hello Kjetil,
Thanks for providing the link .
Debo
http://www.youtube.com/watch?v=hK47qSTLI70
An almost identical approach.
Hi Kostalexis,
Thanks so much for sending this link.
Debo
