Octa Quad misbehaving...
I am up against troubles with Octa (octo) quad.
Motors 1-8 are triple checked, rotation direction & props according to this:
APM_2_5_MOTORS_Y6_X8.jpg?width=350
http://copter.ardupilot.com/wp-content/uploads/sites/2/2012/01/APM_...
tested & retested my radio - roll, pitch, yaw, throttle all proper directions.
Running APM 2.5 (onboard mag)
V.3.01 Octa Quad
Mission planner 1.2.85
Behavior is very unusual - copter is both over-reacting to minor inputs, and seems to be responding to stick input in cockeyed ways - using mixtures of motors that move it sometimes opposite of what should be happening.
Despite my searches, definitive help eludes me.
This is my first Octa Quad, but have successfully built & flown flat Octa, and quads.
Any help would be marvelous.
~jake
3691073813?profile=original
  • MR60
    According to your video, you have a wrong motor spin direction.
    I bet you did the same mistake as I did : when looking at the wiki spin motor direction, for the motors that are on the bottom, be careful that if you setup the spin direction for these motors in the upright position, the spin direction will be reversed once you flip the motor to fix them on the bottom of your ring.
    Also the propellers must all be installed with the writings on them facing up, even for the bottom ones!
  • I believe I just found the answer to my own question.
    My APM 2.5 shipped early this spring (2013) - and had an outdated ATmega 32U2 PPM encoder.
    Found the update instructions here:
    http://copter.ardupilot.com/wiki/common-ppm-encoder-apm2x-atmega32u2/
    ...and just succeeded the install.
    (sidenote: found this little critical bit somewhat buried on this page: http://ardupilot.com/forum/viewtopic.php?f=9&t=4351 on "how to upgrade #4")
    Now, on to testing!
    ~jake
DIY Robocars via Twitter
Oct 23
RT @_JonMyer: 🏎 We need your help in naming my #AWS DeepRacer Underground Track 🏎 @davidfsmith's track is going to be referred to as 𝗔𝗪𝗦 𝗗…
Oct 22
RT @gclue_akira: 仕事もおわったし、電脳化にとらい #マリオカートハック https://t.co/4IU90hCLgm
Oct 22
This is the hashtag to follow all the people in Japan who are hacking the new Nintendo Mario Kart with the real AR… https://twitter.com/i/web/status/1319281354664677376
Oct 22
RT @gclue_akira: @chr1sa @diyrobocars jupyter mario https://t.co/P0oHdjlCRq
Oct 22
RT @_JonMyer: 🚨Our 1st AWS DeepRacer Community Race is Underway on http://twitch.tv/aws 🚨 Join us to find out which member of your commu…
Oct 20
Oct 19
RT @BackyardRobotcs: After an admittedly long wait, the new Tinymovr R3.3 motor controller is now available https://tinymovr.com 🥳
Oct 19
RT @_JonMyer: 🏎 1 hr left before the #AWS #DeepRacer Community 🏎 Top 5 Race tomorrow LIVE on Twitch 1st Place = $50 Amazon GC or AWS Credit…
Oct 19
Oct 16
Oct 15
Oct 14
RT @davidfsmith: Race virtually with The AWS DeepRacer Community Race and then join us on the track to see how your times compare on the ph…
Oct 14
Oct 14
Hiroki Tanaka liked Hiroki Tanaka's profile
Oct 13
RT @breadcentric: It's now!
Oct 13
