(solved)ODD YAW. the quad turning left and right without touching yaw stick
 hello.
i`m do not use english, so If i against the courtesy Please acknowledge it beforehand.
i`m flight testing for a month.
arducopter v 3.4.2
problem is my quadcopter is random turning YAW.
pitch and roll is pretty good.
but Yaw is turning left, right about 20~50 degree. without stick touch during hovering.
flight mode is use Alt hold, loiter.
i don`t know why my quad is turning left or right...
i`m already changed another PIXHAWK FC, M8N GPS( external compass ), calibration Motor and compass, rearrange ESC, BEC, receiver and wire.
But same problem is occur.
This problem is making me crazy.
Attach the log.
please help me my problem.
thank you.
after YAW Autotune, problem is solved.
Thanks!
There's the potential it could be external magnetic fields or an environment that distorts the compass's detection of the earths magnetic field. Is your YAW registering a change in angle if you keep your UAV due north and simply translate it left and right? If so it could be due to magnetic field interference. I've ran into this operating my UAV indoors.
Thank you for reply.
i`m solved this situation.
after Yaw Autotune, this problem is solved.
have a nice day !
Thanks.
