Hello all, I was just wondering what's going on with my setup. I'm using a Dragonlink ver. 2 Tx and Rx. PPM output channel 12 to the pixhawk and in manual mode, the servos are very erratic and twitching violently. I am quite perplexed... Any idea what it could be? I'm still setting it up so FPV video is not running. The only Tx running is the Dragonlink...
I ended up reducing the channels on my Futaba 14SG and it works now, which is a bummer, because I want to use all 12 channels and it seems that the problem is with Dragonlink's firmware...
No I didn't, but come to think of it, that's a good idea.
I didn't know I had a choice of how many channels? I'm assuming the DL Rx is outputting 12 channels out the PPM sum.
So since it's hooked up to a Pixhawk, it will only put out the amount of channels based on what servos are hooked up to the Pixhawk at the time of binding?
Im actually just in the process of setting it up so currently I have 2 channels, 2 the elev. and rudder.
You should probably post this question on the RCGroups DL thread and see what Mike has to say.
