Pixhawk / Dual UBEC Distribution Board VI ISSUE
Hello all,
Maybe anybody know what wrong. I take two "Dual UBEC Distribution Board VI Sensor 120A 10S for APM Pixhawk PX4"
3691282004?profile=originalAnd try use with Pixhawk. Everything fine but current sensor do not work. Or maybe work but current every time 0.0A
3691281960?profile=original
3691281874?profile=originalOther power module work fine but with "Dual UBEC Distribution Board VI Sensor 120A 10S for APM Pixhawk PX4" I have this problem. Maybe anybody know how solve and use this board ?
  • Well, if at 5A you will get 0,15v and at 20A 0,6v , then your solution is good .
    Be aware , I got at 10A a precise measure  but  values become non linear (greater) for lower Ampère , from 10,5A to  30A the readings change very little while higher was  11A.
  • Yes, I am not an electronics engineer but I have tested the replaced 0.5ohm resistor with the 10k ohm resistor and at 10A I get a current voltage of about 0.3v. so assuming it is a linear correlation then at 100A it should not exceed around 3v. I did test the previous 0.5ohm original and at 10A I was getting 0.005v which is not really a measurable voltage for the flight controller. I do not know if it has any other collateral effects on anything else but I assume not.
  • Hi, 10K  is 20.000 times more that the original value , it seems to me a very high value for a shunt resistor .
    http://www.measurementest.com/2010/08/how-to-measure-current-using-...
    Did you measure what is the voltage output  at 10A or 20A ?
    If it is to high there is the risk of damage for the flight controller.
    How To Measure Current Using A Shunt Resistor
    A test and measurement website for engineers, technicians, scientists and academics.
  • Hi Guys, I bought these 120A Ubecs aswell and had the same problems. The current sensors would not output a reading. I then bought some more cause I thought it was just a faulty one but it wasn't they are made/manufactured defective. But good news is read the above and was able to fix it. All you have to do is change the 0.5ohm resistor with a 10kohm one. If you want a pic of where this is I can show you. But you will need a hot air gun to remove it.
  • Matt,
    Thanks fore the heads up on the Mauch boards.  I have had a heck of time finding power modules > 90 amp.  I was going to try a AttoPilot next,  but the Murch board look like a great option.  My heavy lift hexa is capable of drawing > 170 amps.
    Rich
  • The only current sensors I've found accurate are the Mauch Electronics.  If you want a high-quality, reasonably-priced sensor/UBEC, I'd highly recommend them.
  • Low currents are hardly displayed so the current sensor might seems not to work but in fact if you use more Amperes it will work.
    The big problem is that the current sensor gives wrong / non linear values.
    All readings below 10A are overrated , i.e. real 3A appears 4,8A , around 10A , measurement is ok but after the highest measurement I got was 10.8A, even if Ampere drawn was around 28.
    I had the same result on the two boards I own,
  • Alex,
    Have you tried entering a value in the measured current box, something like ".3" for 300 milliamps?
    Current and voltage sensors will always need to be calibrated.  You may need to give it an initial value to work with, and follow up with a DVM or ammeter to get more accurate results.  I use this power analyzer from HK:  http://www.hobbyking.com/hobbyking/store/__75944__Turnigy_180A_Watt...
    but if you have an Frsky Transmitter/Receiver you can also use their voltage/power sensors to calibrate the power module.
    I calibrate voltage and current at 50% throttle, since this is close to my normal operating throttle.  The power modules are usually non-linear, so you want your most accurate measurements at close to your normal operating voltage and current.
    I think Randy has a good video on calibrating the power module for APM, you may want to take a look at that.
    Rich
  • Hi, I have the same issue .
    Guess it is a defective  Ubec board...
    On Hobby King I found this message:
    Alainthumb_up.png 1 points - 8/2/2016
    Did tests on the board, all was good except their was no current output. Having no schematic of the board, i looked into it. I noticed a INA169 current sensor ic. The output of this ic requires a load resistor on the output. There was one, but of 0.5 ohm(a short). The typical load resistor should be 50Kohm to get a 50x voltage gain in order to to output about 3.0Volts out, compatible with usual ADCs. Conclusion, the board was assembled with the wrong resistor.....i suspect it happened on other boards from that batch, which might explain why it is in backorder......
    As far as I know all the boards have 0.5 ohm load resistor just like original Apm 3Dr supplu module.
DIY Robocars via Twitter
RT @a1k0n: @SmallpixelCar @diyrobocars It's just something that's easy to track with chroma keying. I ended up using different colors on th…
Monday
Monday
RT @TinkerGen_: "The Tinkergen MARK ($199) is my new favorite starter robocar. It’s got everything — computer vision, deep learning, sensor…
Nov 23
Nov 23
RT @roboton_io: Join our FREE Sumo Competition 🤖🏆 👉 https://roboton.io/ranking/vsc2020 #sumo #robot #edtech #competition #games4ed https://t.co/WOx…
Nov 16
DIY Drones via Twitter
First impressions of Tinkergen MARK robocar https://ift.tt/36IeZHc
Nov 16
Our review of the @TinkerGen_ MARK robocar, which is the best on the market right now https://diyrobocars.com/2020/11/15/first-impressions-of-tinkergen-mark-robocar/ https://t.co/ENIlU5SfZ2
Nov 15
RT @Ingmar_Stapel: I have now explained the OpenBot project in great detail on my blog with 12 articles step by step. I hope you enjoy read…
Nov 15
RT @DAVGtech: This is a must attend. Click the link, follow link to read the story, sign up. #chaos2020 #digitalconnection #digitalworld ht…
Nov 15
RT @a1k0n: Got a new chassis for outdoor races (hobbyking Quantum Vandal) but I totally didn't expect that it might cause problems for my g…
Nov 11
First impressions of the Intel OpenBot https://ift.tt/36qkVV4
Nov 10
Nov 9
Excellent use of cardboard instead of 3D printing! https://twitter.com/Ingmar_Stapel/status/1324960595318333441
Nov 7
RT @chr1sa: We've got a record 50 teams competing in this month's @DIYRobocars @donkey_car virtual AI car race. Starting today at 10:00am…
Nov 7
Nov 6
RT @a1k0n: Car's view, using a fisheye camera. The ceiling light tracking algorithm gave me some ideas to improve ConeSLAM, and having grou…
Nov 5
