Hey all, well its been a frustrating time here with the newly purchased pixhack. I purchase a genuine CUAV unit and was told I could run APM/PX4 stack with out any issues, but I simply cannot do it.
I have done pritty much everything I could think off to run it in mission planner with updating to latest firmware first, then older firmware, still same issue.
The problem I have is below;
1. boot up via usb GPS plugged in, safety switch plugged in, external LED plugged in.
2. Pixhack begins for a few seconds then, little LED flashing red/blue along with white light solid...
3. this is where it stops... nothing more.
NOW, while I CAN update the firmware to the latest firmware (heli) in this instance, it never initializes from what I can tell. I have looked at the logs and it states a repeating error: Initialising APM, then Error: check BRD_TYPE: no lsm303d found???????????
As far as I am aware, the lsm303d my pixhack HAS a lsm303d acc/mag????
have I bricked this thing?????
As mentioned NOTHING that I do solves this issue. I have reset the unit via holding down safety switch, reseting via little side buttons and power on. I have googled the hell out of it and nothing is working...
so....before I pack it away and buy something else...can anything be done here you think?ANY assistance would be great!
You probably have a failed sensor (the lsm303d). With current master you could still use the board like this:
  • install the 'latest' test firmware (use control-Q in MissionPlanner to load latest)
  • when it gives the BRD_TYPE error, go to the advanced parameter list and set BRD_TYPE to 2
  • then reboot the board
what that will do is force it to identify as a pixhawk. It will then fail to start the lsm303d sensor driver, but you would still be able to use the board with one IMU (the MPU6000).
Yesterday I had the same problem and the same errors but with 3DR Pixhawk Mini. I tried to set BRD_TYPE manualy but then it shows other error msg, something about other sensor, I don't remember. Now I have firmware from QGroundControl and it works fine but not with MissionPlanner that I'm used to.
Anyone knows when MissionPlanner will handle it?
Yes you are correct! I opened QGroundControl an flashed px4 firmware stack not apm and no errors????? Strange?? Seems to be working but really not use to using this software..i really would like to use mission planner but it looks like it's not going to happen :(
I tried the change the brd type as well as mentioned but nothing works.. Would luv a resolution if possible!
Yeah Im curious when mission planner will be able to achieve this?
I'm having this same problem, looks like I can only use the PX4 Firmware for the Pixhawk Mini :(
@Pranav, the PixhawkMini works fine if you set BRD_TYPE to 5. If you use the latest master firmware then it will be auto-detected and you don't need to set BRD_TYPE.
@Chad,
Is that with the latest master firmware, or the stable release?
With master if you set BRD_TYPE=2 to force pixhawk then it will skip the board type detection and just try to start drivers. If the lsm303d driver fails to start it will accept that and just run with one IMU.
So when you say "nothing works" can you explain what that means?
I suspect you are either not running master or you have not successfully set BRD_TYPE=2.
Cheers, Tridge
Hi Andrew,
I am trying to use the latest firmware release (heli) from the firmware flashing page. I connect and it does it thing, uploads the new firmware and finishes. I then re-connect and thats where it stops with the error.
Now, I have gone into the Advance Params and found brd_type. I changed that from 0 to 2. aka pixhawk board type as it states in the window. I then WRITE params and then disconnect and reconnect the board...same thing happens no change still same error.
One of the other frustrating things is that if I want to use previous firmware like 3.3.3 for example, It uploads fine, BUT will not connect to mission planner AT ALL the board just gives me a solid red light...it times out and will not connect. ONLY the latest release of the firmware will connect with solid white/purple light on the board
I find this strange but then again I dont know all the ins and outs of these boards to well..
if I am doing this incorrectly, please let me know as this is so frustrating as you would expect.
thanks again!
Andrew Tridgell said:
@Chad,
Cheers, Tridge
Hi Chad,
If you really are running master then getting the "Check BRD_TYPE: no lsm303d" error makes no sense, as that error doesn't exist in master.
If by "same error" you mean some different error message then please let me know what that exact error message is.
Cheers, Tridge
Hey Tridge,
appologies if I have been a little confusing here, but I was meaning I am still getting the same error. This is my first attempt at arducopter type boards (came from naza) so the learning curve is steep for me.
As mentioned I have simply plugged my pixhack flight controller in (with GPS and safety switch AND microSD card in) into the usb port and waited for the usb to connect as it does in Windows. Then hit the connect button. Now I go to firmware and it downloads the latest firmware for heli. I simply click on the heli picture and it confirms I want to use this latest firmware. the erase begins, the programing starts and finishes successfully. I then proceed to the Advance params and change the board type as suggested and write params. I then remove usb and plug back in...same problem...check brd_type: no lsm303d found, could this be a pixhack thing?
As for when you say "Master" what are you refering too? am I not loading the right firmware? am I meant to be using Mission Planner for this? or some other software?
Cheers
Hi Chad,
Cheers, Tridge
Hi Chad,
ok, sounds like you are using the latest stable release, not "master". I should have explained better.
The "master" release refers to the latest alpha development code. To get the option to load that you you need to type control-Q while on the "install firmware" page. You will see the version numbers offered change to 3.5-dev.
Basically what is happening is this:
  • the 3.3 release checks for sensors in early bootup and gives the red LED if a sensor is missing
  • the 3.4 release checks for sensors after the link to MissionPlanner starts, and gives the BRD_TYPE error if it can't find a sensor
  • the 3.5 release skips the sensor check if you have already set BRD_TYPE. This is what you will need
note that 3.5 is unstable firmware, I'm suggesting it to give you a preview of what is coming, as it happens to solve your issue (or not so much solve, as allow you to fly with a bad IMU).
Cheers, Tridge
Many thanks Tridge,
this makes sense now, I will give it a go an let you know how things go!.
Cheers bud
Hi Chad,
Cheers, Tridge
