It looks pretty good, but don't know will it open source the PCB files.
provided you would even get the pixhawk!!!
in fact, the majority of people actually lives outside of the us...
and as long as they just follow the reference design i do not see why there should be an issue... chinese can assemble a pcb as well as mexicans can, if not better. they have lots of experience building most of the electronics for the west for the last decade.
Very nice design, easy to make modular setup.
I would guess the IMU support is soft silicone, wouldn't be much point in it otherwise.
Input connectors will hopefully work better than DF13's and not require corporate loan to purchase crimper for cable ends.
Aluminum case should have no appreciable negative effect on the magentometer, aluminum can damp DC EM field but lag should be small.
And the aluminum will actively damp the AC field generated by the ESCs and motor which is a good thing.
Also, they are really bound by the Open Commons requirement to provide (adequate) schematics and PCB layout although what we have seen so far is that the Chinese are playing very fast and loose with their interpretation of what they are actually providing.
HK's Pixhawk clone for example provides a PDF with unusable PCB layout pictures, not files and no schematics (last time I looked anyway).
Nice design - side ports cable interface instead of top ports.
Hope it would be available soon.
Shame they didnt add a local minimosd on the board that is hardwired to the telemetry port.
These connectors are great, I have some, easy to remove with positive latch! I got them from a Sharp LED TV recycle. Very Good choice!
Even if the vibration damping does not work, they tried to think out of box unlike 3DR.
I didn't know Hobby King made a Pixhawk clone. Got a link?
This clone is still in pre-order. However, the (pre-order)price is China is cheaper than $180. Also it's pre-loaded with OTP data, so it's easier to upgrade firmware in MP. This manufacturer is famous for its high quality APM clones in China. So this pixhack should be more reliable than other Chinese clones. But one thing I'm still afraid of it that, in order to reduce costs, some parts are removed from some clones, for example the ESD filter on USB or USART port.
There is no HK Pixhawk clone that I can find, you must be referring to the HKPilot which is an APM 2.5.2 clone.
Very nice design. Plugs & ports are better than 3dr I think.
Great design! This is a very good idea to place only the Acc+Gyro on a dampened mount.
I wonder if this vibration filter is better than a global dampening of the whole card as this remote IMU  will be very light with less inertia, so it won't filter high frequency noises.
On the other hand, the amplitudes of the disturbances will probably be lower... so the right question is to know which of these 2 effects (high freq noise and disturbance amplitude) bring the most issues.
If dapener is made with flexible silicone, I fear the IMU mouvements will prematurely wear the ribbon cable connections.
That would be a fatal issue for the UAV embedding this PIXHACK card.
