After calibrating the gps and accel several times I still have a left roll on my quad, I run a Taranis tx with a X8R rx on 4S battery. I was told that my compassmot was not set correctly but after several resets it still moves left with the right stick centered. And I have re-calibrated my radio many times over. Any other suggestions before i smash this crappy thing.
One question, are you using rc channel mapping so that channel 1 is Throttle?
I use sbus from my X8R rx and on my Taranis the throttle is channel 3
That sounds good.  Will need a log of the flight then to check a few parameters for issues.
Not sure how to get a flight log but I will try and see what I can do. I have just completely reinstalled everything from MP to the latest FW and I hope to get a good test flight today.
I have an 9XR Pro radio with X8R receiver and it works great on my quad copter.
To get the log you need to connect using a USB cable and then from Mission Planner on the HUB menu select Data Flash Logs from the buttons in the bottom section.  Then select Download Data Flash log via Mavlink.
Yes I have done that and I get a bunch of files that say 1.BIN thru 65.BIN that I can't open of upload to this site.
I use one drive or google drive and post the link here.  Just make sure you set the file share to public view.
Ok, from the logs I didn't see anywhere where you had the sticks level.  I do see that motor 3 is running a little harder than the rest which should cause the copter to lean right.  You say it goes left so it could mean that the copter is heaver on the left or the wind is blowing against it.  In either case I don't see the issue.
Thanks for the help and your reply
Hi Bobby, I have been looking at your log and other that not being tuned well, I don't see a problem. I did notice that you only flew in stab or althold. I also see that you heading was constant. If you are constantly applying stick input more or less in one direction, its just you fighting the wind. Have you tried loiter mode yet ?
APMCopter is not a crappy thing. Thousands of users are totally happy with its performance and I am one of them. Go to a large open area on a calm day and try loiter mode. I think you will be supersized. You will get there, don't give up. Also there is no such thing as a GPS calibration, do you mean magnetometer ?
I meant the compass calibration. And yes I have tried loiter mode and it did hold pretty nice. I think that some of my problems are from vibrations and I have a pixhawk anti-vibration mounting base on order now. I"m going to remove the pixhawk and mount it onto the new base mount. Then I'm going to re-calibrate everything over again from start. And if my stable and altitude hold modes are as good as this time around I will take it out and do an auto tune flight and see if thing get even better. But it does hold fairly nice in loiter.
