PixRacer with Ardupilot
This is a discussion to focus the feedback and support of ardupilot on the PixRacer board from AUAV.co.
We believe that all teething problems encountered are now resolved and so we recommend people load Copter-3.3.4 which is available for all multicopters through the Mission Planner's (and other GCS's) Install Firmware screens.  Note that because regular Pixhawks are still on Copter-3.3.3 the install icon may show Copter-3.3.3 but rest assured, Copter-3.3.4 will be installed (you can check the version by looking at the very top of the Mission Planner).
3691274249?profile=original
  • Nice option, another one is a X 2.1 f board if fit.
  • In the blog post on the Convergence, I measured 168Hz for the FrSky converter.
    That was independent of the value for parameter SERIAL_SBUS_RATE, which defaults to 50Hz.
    If you have an oscilloscope or logic analyzer you should check what you're actually getting. Yours might behave differently due to firmware changes. Here's the point in the PR log where someone else thought he was seeing 50Hz: https://github.com/ArduPilot/ardupilot/pull/7270#issuecomment-34734...
    add library AP_SBusOut by kd0aij · Pull Request #7270 · ArduPilot/ardupilot
    supersedes #6794 Adds support for SBUS serial output in AP_HAL for all vehicle types. This PR implements the UARTDriver configure_parity and set_st…
  • Hi Mark,
    Ah gotcha regarding the frame rate. I just purchased the FrSky 4 channel one you suggested, so we'll see how we go with that. Any idea of its frame rate?
  • That looks good, too. Beware that some sbus to pwm converters will output frame rates > 50Hz, which might be a problem with analog servos. If you're using ESCs or digital servos, that's OK.
  • Also this: https://hobbyking.com/en_us/sbd4-4-channel-s-bus-decoder.html
    SBD4 4-Channel S.BUS Decoder
  • Glad you like it. I just noticed that there's now a very tiny single channel converter from FrSky: https://alofthobbies.com/frsky-sd1-sbus-converter.html
    Of course, without the pins and wrapper, the 4 channel one is also pretty small.
    FrSky SD1 SBUS Converter
    A compact and easy to use SBUS decoder to convert any conventional servo to an SBUS compatible servo.  This decoder converts a single SBUS channel to…
  • Wow, that's fantastic, Mark!
    Thanks so much. I only need two extra channels, and space is so limited. I need to get a very tiny converter, but this is great :)
  • you could use Sbus and a PWM converter as described here: https://discuss.ardupilot.org/t/e-flite-convergence-with-pixracer-a...
    Sbus supports up to 16 channels, and there are both 4 and 8 channel sbus to PWM converters on the market. So using one 8 channel converter would give you a total of 14 servo outputs.
    E-Flite Convergence with PixRacer and SBUS output
    Previous conversions of the Convergence to ArduPilot have used the Pixhawk1 flight controller (E-flight converge default file, E-flight Convergence d…
  • Is there any way at all that the PixRacer could be miraculously transformed such that it'll handle 8 ESC signals? I need something small for a coax octocopter that will a) run ArduCopter and b) fit the 30.5mm x 30.5mm (hole centres) board format.
    I'd be most grateful for any suggestions / advice etc.
  • The PixRacer does not have an analog input pin dedicated to airspeed input. I use the MS4525 and MS5525 digital sensors on I2C instead.
    Juan C Ricardo said:
    Hi guys:
    Anyone knows here if I can wire an analog speed sensor to pixracer ?
    regards and thanks in advance !
    jc
DIY Robocars via Twitter
May 15
May 14
May 13
May 13
May 11
May 8
May 8
RT @SmallpixelCar: Test my car. RTK GPS worked great. Thanks @emlid for their support. https://t.co/EkQ6qmjmWR
May 8
DIY Drones via Twitter
RT @chr1sa: @kane That's @diydrones circa 2009. Still have a box of those Canon cameras that we used to strap into planes, just like this.…
May 3
RT @chr1sa: Our next @diyrobocars race is going to be outside at a real RC racetrack in Fremont on May 28. Fully autonomous racing, head-to…
Apr 30
RT @f1tenth: Our Spring 2022 F1TENTH course @PennEngineers is coming to an end with a head-to-head race as a big finale. So proud of our st…
Apr 26
RT @DanielChiaJH: I wrote a thing! Throughout the development of my @diyrobocars car I've been using @foxglovedev Studio to visualize and d…
Apr 23
RT @SmallpixelCar: My new car for high speed. Low body, everything ( @NVIDIAEmbedded Jetson Xavier NX, @emlid RTK GPS, IMC) under the deck…
Apr 23
Apr 21
RT @f1tenth: F1TENTH Race training setup @PennEngineers for our upcoming ICRA2022 @ieee_ras_icra competition. @OpenRoboticsOrg @IndyAChalle…
Apr 21
RT @fatcatFABLAB: Proud to be hosting a restarted DIY Robocars NYC Meetup April 26. Come by if you want to talk about and race self-driving…
Apr 17
