Hey guys, Im no expert here, however I did notice that after upgrading Mission Planner from 2.1.48 to 2.1.49 and 2.1.50, the geo referencing is way off on the estimated seconds. In 2.1.48, my seconds offset was 265 sconds for the file and log I was using. After doing the update to bot1.49 and 1.50, the seconds offset for the same log and file has become 70945.xxx seconds. I notice after hitting the estimate button, it say the log file is from ONE DAY before the actual log was created. ie: log created on 05-06-13-15-32-17. After clicking estimate offset, it then shows the logs min and max date as being 05-05-13 which after looking at the seconds offset, equated to 19 hours.  Not sure if there is a bug in the new release, but the only way I got it to work was to go back to the Mission Planner v2.1.48
  • Micheal, I have a question for you about adding an option for the Joystick interface. I noticed that button commands are strictly for flight modes only. Is there a way to incorporate momentary servo actuation on Ch 5-8 as well into the options menu? My intent is using the trigger for camera triggering.  Also, I noticed that when I put servos on any channel other than Roll Pitch Yaw and Throttle, I get no response from the servos, ie: hooking ch5-8 up for a gimbal control. Any ideas? I have calibrated the joystick and it works fine on the first 4 channels, just not the rest.
    Extremely grateful for your help
    Jamie
    the issue I because the offset numbers have changed.
    the lat long alt numbers
    they where
    4,5,7,9
    now are
    3,4,5,8
    if you change them it should revert to the old style
  • Also, I wanted to ask about how to calculate the two FOV values. My angle offset is also an odd negative number as well in order to line the pictures up. I use on picture to play with the settings until I get it lined up thinking it will be the right setting for the whole batch, but when I apply it to the mass of photos none of the others are anywhere close to orientation and offset as well as frame fit to scale... Any pointers?
  • Im using a tlog
    are you using a tlog, or a dataflash log?
