PRESSURE WASHING TETHERED UAV
I need some help finding somebody capable of helping me build a UAV that can carry heavy loads, needs to be tethered with power/video lines and also pressure washer hose, needs to have GPS functions to keep it stable and program grid patterns so it can clean a building with out missing any spots.Please contact me if you are interested in this project, thank you.
  • Rui-
    Yes, the sprayer system can spray under autopilot control. I posted a thread about it last year here.
    http://diydrones.com/profiles/blogs/heavy-lift-x8-and-sprayer-system
    Let me know if you have any other questions and I will be happy to answer them.
    -Brian
  • Hello Brian! I am too trying to built a multicopter for spraying in agricultural settings... I build a quadcopter with 8Kg of thrust in total...
    Your multicopter is capable of spraying in autopilot? Can you tell how your spraying system works?
    I would be very thankful if you sent me the link to the build you send to Erick..
    Thank you very much,
    Brian Riskas said:
    Erick-
    I built a large X8 multicopter and sprayer system last year that was used for spraying in agricultural settings. The platform might be useful for your application. I sent you a message with a link to the build.
    -Brain
  • Not sure to understand what you want to realize but IMO it is not possible to build a multirotor that will hold the thrust of a pressure washer hose , we are talking about several kg of thrust and  where do water will come ?
    A tube that old water pressure weights a lot and no multirotor will be able to lift it .
  • Hello,
    GPS is not going to help you with your project , you nee pattern & color rocodition paint vertical wall. Large Argo drone can be modified for this perpus. done Similar project already .
  • Hello Brian, thank you for your reply, I saw your website, I have a few questions, do you think you could modify the multi copter with some type of GPS gadget that will scan a wall and fly in a grid patters with out missing any areas while spraying? also I was thinking of a device that can hang from the top of the building so it could hold the load of the tether instead of having the multi copter carry the weight. I was also wondering if there a way of making the UAV stay still while releasing the water through the high pressure nozzle, obviously it's going to have some type of "recoil" effect. I'm sure  I'll have more questions since I'm just starting this project, but do you think you could give me an estimate on how much would this build cost and what the specs regarding lift and weight load capabilities would be? my email is erickgibbs@gmail.com. I really appreciate it, thank you.
    Brian Riskas said:
    Erick-
    -Brain
  • Erick-
    -Brain
DIY Robocars via Twitter
RT @chr1sa: Our next @DIYRobocars virtual AI car race is next Saturday. Compete from home using the @donkey_car simulator -- no physical ca…
4 hours ago
RT @RoboticMasters: Students from @Sydney_Uni working hard on improvements and changes to @donkey_car simulator. @diyrobocars @adafruit…
4 hours ago
Practice virtual race this Saturday; the real thing will be on Oct 3 https://www.meetup.com/DIYRobocars/
Wednesday
Wednesday
Derrick Davies liked lisa TDrones's profile
Wednesday
Sep 21
RT @SahikaGenc: AWS DeepRacer & Hot Wheels Track https://youtu.be/4H0Ei07RdR4 via @YouTube
Sep 14
Sep 8
RT @davsca1: We are releasing the code of our Fisher Information Field, the first dedicated map for perception-aware planning that is >10x…
Sep 8
RT @SmallpixelCar: How this works: 1)object detection to find cones in single camera image, 30 frames/sec on @NVIDIAEmbedded Xavier. 2)comp…
Sep 8
RT @SmallpixelCar: Use two color cones to guide the robocar. No map needed, on onsite training needed. Just place the cones and it will fol…
Sep 7
Sep 7
RT @roboton_io: Great to see http://roboton.io running at 60fps on the cheapest #chromebook we could find! #edtech #robotics #educat…
Sep 3
RT @openmvcam: Crazy in-depth article about using the OpenMV Cam for Astrophotography: https://github.com/frank26080115/OpemMV-Astrophotography-Gear https://t.co/BPoK9QDEwS
Sep 3
RT @openmvcam: Hi folks, it's finally here! Our first draft of our Arduino Interface Library is out! It works over SoftwareSerial, Hardware…
Sep 3
RT @chr1sa: Please let them have an open API. This would be perfect for @DIYRobocars races https://twitter.com/NintendoAmerica/status/1301513099707658246
Sep 3
