Hi together
I have a problem that i didn't have before.
I have made a new hexa frame with new controllers and motors.
Controllers: 60A Hifei
Motors: A2820-6 1000kv
LiPo: 4S 5800mAh
Problem:
If i want to lift of my hexa, they will made a turn into the ground. I test it 4 times. It is not the same direction, so i am absolutely confused.  I have no idea what is wrong.
I test the direction of every motor and prop twice. Also the cables from and to the board. Thats all correct. Also i watch all the settings and all works nice.
So the hexa will be a "big berta" but i have made bigger ones without any problem.
Does everyone from you can help me ?
Pictures from my hexa frame you can find here
Thx for answers
Might seem simple but do you have the props on correct way ?
Hi
Yes for shure. That was the first that i test it.
I first use this 60A Hifei Controller. Is that possible that they work to slow ?
The motors will be good i use it also in a other project.
