Tags:
I will use it for fpv with eagletree system osd and data recorder.
just got it and just have a few flights to get used to how it handels, built as per directions no mods.
Hi. Where did you but this? I am also looking for to equipt my projet mq-9 whit motor, esc and propeller, but i dont know where to buy or what...
Hi All,
I just placed a order for a new Projet MQ-9 Reaper 98" and would like some feedback on what parts should I get for it as for as the size servos, motor, esc, etc? and anything else that you'll can assist me with on this build.. Thanks
Why?
Brushless power and LiPo batteries have made the smaller fuelers almost obsolete, especially when you take the noise and mess into consideration.
And like Matt mentioned, cooling and vibration are sure to be a problem.
Hi All,
I gotta say, I like what you're doing with your Reaper. I just started mine last week and I saw your reply in this thread. I actually bought just about everything you have there. Don't worry... I won't hold you to this design... :-)
I see your using the E-Flite 46 Outrunner so I did the same. My only problem right now is how to mount the outrunner in the Reaper. It looks like this motor needs to be an inrunner to mount inside. Did you mount it inside or out? If you did mount it inside, how?
Thanks for your info in this thread. I think you have the right idea.
Joe
45 members
1472 members
282 members
470 members
57 members
Powered by
