Hello,
I recently started working with an Ardupilot. I have connected a uBlox LEA6 receiver to it. I am currently trying to get pseudorange data from the LEA6 and it seems like I have to get the RXM-RAW packet from the receiver. I was wondering if anyone had done this before or would have any sample code ardupilot code?
I have looked through the RTK library and the GPS_Auto but I haven't been very successful in printing out pseudorange data. I believe you need the structure from the RTK library to place into the example GPS_Auto code. However I am unsure where exactly the Ardupilot is choosing and filtering packets from so I am unsure of how to retrieve packet data.
Derek,
Only the 6T and 6P  modules produce the RAW data packets.
Check my blog post here for some work I did with raw carrier phase data from a 6T -
http://www.diydrones.com/profiles/blogs/proof-of-concept-test-extre...
Doug
Thanks for the reply Doug,
I had previously seen your blog post and I was hoping to obtain similar data. However I saw that the product did not seem quite ready yet.
I was wondering, if I wanted to use the Ardupilot to collect pseudorange and carrier phase information, would the following be a correct way to go about it?
  1. Obtain a NEO-6P and solder wires into an Ardupilot GPS cable
  2. Write an interface to parse the RXM-RAW packets that get produced
Thanks,
Derek
There are other UBLOX GPS options that put out raw as well:
- Neo 7P (easier to find these days than the Neo6P
- M8T
To verify, I have successfully used both NEO 6P and 7P with RTKLIB
Hey B_Duffy,
do you have a setting file to upload to use the M8T with the pixhawk?
Having problems getting it working.
Thanks Michael
