I'm trying to write waypoints to my APM board using QGC but I get the error "Operation timed out"
I think it's because QGC says my rover is in "Uninitialized mode".
QGC keeps saying: "Uninitialized, booting up" where it shows you the status of your UAV.
How can I fix this?
Any help would be appreciated.
I'm also using ArduPilotOne (Ardurover).
-Junior
Tags:
I just tried using my xbee and I think the xbee works.
Yes I do get populated parameters with the xbee.
But still same "time out"
Thanks alot James! I just saw you update the google code site. I will be waiting patiently for tomorrow :)
I wish I could help find the bug but I don't know much about jtag debugging :(
But how did your ArduRover code work in your youtube video here:
http://www.youtube.com/watch?v=r1iJWIKbAQc
if the bug was still present at the time?
That sounds like great news!! I can't wait!
I am on standby for testing :)
Do you know which revision of ardurover worked by chance in the video? (if you already fixed the timeout issue disregard this question)
Hi James I tested your latest ardurover code.
Waypoint sending and recevieing seems to work, however only when gps is disabled.
When I enable gps I seem to get timeout errors still.
I'm using ftdi cable to connect to telemport to avoid any possible xbee wireless errors if that helps.
Also sometimes my ftdi connection and xbee would crap out and stop sending data and I have to restart my APM board. Weird.
45 members
1472 members
282 members
470 members
57 members
Powered by
