Hello
I have two questions about the flight copter in RTL mode
1) why, if the GPS is disabled and enters RTL copter goes to a height of 200 m and there is still a chaotic movement?
2) What happens if the motion mode RTL copter GPS loses the signal from the satellites?
If there is no GPS fix, LAND mode is trigged instead of RTL.
The default RTL altitude is 15 meters and can be changed from Mission Planner.
Olivier
Hello,
-RTL does not work without GPS obviously, otherwise how would AMP know the way ?
-There is a RTL default altitude of 100m that you can change in the flight planner screen of mission planner. That surprised me too the first time when I saw the quadcopter climb very high and I did not know why.
I do not know what would happen in case you loose GPS during RTL, I guess the copter is lost...
