RFD900, RFD900+ - New long range radio modem
Hi All,
I would like to introduce you to a new radio modem that we developed for very long range datalinks!
http://rfdesign.com.au/RFD900.php
Some of the key features of the RFD900 are as follows:
  • Multi point and point to point link capability.
  • Long range >40km depending on antennas and GCS setup.
  • 2 x RP-SMA RF connectors, diversity switched.
  • 1 Watt (+30dBm) transmit power.
  • Transmit low pass filter.
  • > 20dB Low noise amplifier.
  • RX SAW filter.
  • Passive front end band pass filter.
  • Open source firmware / tools, field upgradeable, easy to configure.
  • Small (30 x 57 x 13 mm), light weight (14.5g).
  • Compatible with 3DR / Hope-RF radio modules.
  • License free use in Australia, Canada, USA, NZ.
These modems are designed to support long range applications, while being easy to use and affordable.
These modems have been flying in various platforms and have demonstrated excellent performance in real applications.
RFD900 modems are now available at: http://store.rfdesign.com.au
Support within APM planner and the radio configurator from Michael Oborne is already available.
It works seamlessly with APM planner, all radio Mavlink parameters are available.
Update, December 2014:  The RFD900+ with improved specifications is available now at:
http://store.rfdesign.com.au/rfd-900p-modem/
Seppo Saario
rfdesign.com.au
Hi Chris,
Thank you for your advice. I use the 3DRRadio config for configuration. But I did not found the option to inject the MAVLink RSSI. Could you tell me which configuration tool you use?
Jason
Hi Jason,
No probs, we are all here to help each other.  Try the RFDesign site.  http://files.rfdesign.com.au/tools/ should have the RFD config tool which has the option 'Mavlink' in the lower left side.  This should inject mavlink RSSI messages in if it detects MAVLink is being used, it seems to strip the other RSSI messages out so it doesn't confuse the GCS.
Also I was running an SSH session over the link at the same time and it worked well.
Chris
It has been a long time since updates!
We have been working on a lot in the background.
A 900 MHz RCLink solution will be available very soon, within the next 1-2 months.
Telemetry plus concurrent PPM passthrough.
Modems with higher data rates and encryption (finally) are in the works.
We have prototyped the units and pretty happy with their performance.
Sorry for not revealing too many details just yet, but, letting everyone that we are very much on the case.
If there are some people keen to beta trial units and give them a good workout, please send a PM..
Also wishing to thank you for your support over the years.
Seppo
Hi Seppo
Help me to understand a little more how these things work.
When you say
1. "Telemetry plus concurrent PPM passthrough." what does that exactly mean? Same modem ca be used for different functions?
2. "Modems with higher data rates and encryption (finally) are in the works." What is the advantage of these features?
My additional question is that, I figure that some GSM networks use the same band 900MHz, or even other broadcast could be using this band or near it. Now remembering from when i was a child, we grew up near the border with Malawi, some of National radio Channel when listening to the radio, you would also hear in low voice in the background another channel talking. I remember back then radios had a fine tuning knob, so to get rid of the background interference we had to fine tune with the fine tuning knob. In the AUV operations how does interference with other broadcast that may be using same band or nearly same band play part? is there even interference at all? Enlighten me a little on this one please!
ID
Hi Seppo,
Yes, a long time - but good to hear the news!  Over the years, I've purchased 3 RFD900s from you and wanted to know if the Telem + PPM passthrough is a firmware update.  My modems are all RFD900, not RFD900+, if that makes any difference.
Thanks,
Dan
Seppo, a couple other questions - I assume encryption will only be available on the "+" version, true?  And is there any impact on the throughput?
Thanks,
Dan
Hi ID,
A good thing about these modems is that they use spread spectrum whereas GSM is narrow band.  When a spread spectrum receiver de-spreads the incoming signals, narrow band signals are significantly spread out and therefore reduced while the desired spread signal from the RFD modem is increased.  In other words the RFD modems should not be impacted too much by GSM signals, even if their frequencies overlap, IMHO.
Dan
Thanks for this clarification mate
Would you have any comments about the first two questions?
ID
Hi Chris,
I am building the firmware for RFD 9000+ (i think it is RDF 900p as well). I downloaded the source code from branch :https://github.com/RFDesign/SiK/tree/SiK. And Compiling is OK. Then I uploaded the new firmware onto one of my two radio modules.
I found the new firmware version is 1.13.  seems that this version has some problem when using 3DRRadio for configuration.
Another thing is https://github.com/RFDesign/SiK/tree/900p_v1.9.   Is this the latest version for RFD 900p?  I am compiling it. but get some error.
Could you please tell me which branch is better for RFD 900p?
Thank you very much.
I used their prepared binaries (http://files.rfdesign.com.au/firmware/) - choose the one for the 900+, I believe I'm using the 1.9 binaries and they are working well for me.  I also have tried the v2 for multipoint comms.
Try the v1.12  they have on the site, if no good drop back to the v1.9.
I haven't had a need to build the firmware from them at this stage.  I've had a quick look but thats as far as it goes on that one.
ID,
1. PPM is a pulse coded output that holds R/C channel information about servo positions. It is a single pin output that can be interpreted by the filght controller to read the positions of your Radio control stick/switches/etc. What is it for? Well if it is used and you have a flight controller on board, then you will no longer need the R/C receiver, or the R/C transmitter. It will need some small circuit to interface to the output of your R/C controller. We'll be working on that, or users can hack some simple resistors to try it out. The ppm input/output pin is separate to the serial input output pins, and both ports can be used at once.
2. Higher data rates? Well why not, but seriously there may be many people who want this, for example passing low quality video, or just more/faster rate data they want to pass to/from flight controller. Of course there's always a loss of range with higher rates, but usability depends if it is still within your requirements at the desired rate. Encryption? Well I guess just link visibility is an issue for some people.
Kent
Dan,
No PPM is not available on the RFD900+, it is only for the new RFD900x due to be released soon...
I don't think this will be possible on the 900+ due to size constraints and other issues.
Thanks,
Kent
