RFD900, RFD900+ - New long range radio modem
Hi All,
I would like to introduce you to a new radio modem that we developed for very long range datalinks!
http://rfdesign.com.au/RFD900.php
Some of the key features of the RFD900 are as follows:
  • Multi point and point to point link capability.
  • Long range >40km depending on antennas and GCS setup.
  • 2 x RP-SMA RF connectors, diversity switched.
  • 1 Watt (+30dBm) transmit power.
  • Transmit low pass filter.
  • > 20dB Low noise amplifier.
  • RX SAW filter.
  • Passive front end band pass filter.
  • Open source firmware / tools, field upgradeable, easy to configure.
  • Small (30 x 57 x 13 mm), light weight (14.5g).
  • Compatible with 3DR / Hope-RF radio modules.
  • License free use in Australia, Canada, USA, NZ.
These modems are designed to support long range applications, while being easy to use and affordable.
These modems have been flying in various platforms and have demonstrated excellent performance in real applications.
RFD900 modems are now available at: http://store.rfdesign.com.au
Support within APM planner and the radio configurator from Michael Oborne is already available.
It works seamlessly with APM planner, all radio Mavlink parameters are available.
Update, December 2014:  The RFD900+ with improved specifications is available now at:
http://store.rfdesign.com.au/rfd-900p-modem/
Seppo Saario
rfdesign.com.au
Dan,
The new modem will be a RFD900x not a RFD900+. The RFD900+ is the existing modem and I'm not completely sure of the state of encryption on that version, but I can tell you about on the RFD900x.
On the RFD900x encryption is 128 bit and will have a slight impact on throughput. It depends on the data rate, i.e. lower rates (4,64K) it will be less noticeable and for higher rates (128-500K) it's in the order of around 10 % of the throughput. Note that the RFD900x is already substantially better than the RFD900+ for utilization of the available air rate so with encryption on it will likely still be better then the RFD900+. More data will be released, hopefully with some actual numbers once the product is released.
Kent.
Hmmm ... I wonder if Seppo would take a 900 as a trade-in on a 900x ;-)  Kidding!
Thanks for the info, Kent!
Hi All,
I got a couple of these RDF900+ radios and they communicate okay to each-other from my copter to mission planner, However, the range is the same as the  3DR radios.
Do I need to change some configuration to accomplish longer range?
Can they be used with 3DR? and if they do, what configuration should I use?
Picture attached.
Thank you to all in advance for your help.
You should get much better range from the RFD900's compared to the 3DR style radios. Yes you can mix 3DR radios with RFD900's as long as you dont try the multi node stuff with the 2.x firmware.  I get around 1.5 times the range just with a straight and 90 degree quarter wave antennas but it depends on the environment you are in.  Once you lose radio LOS it will go downhill very fast.  Depending on your locality you maybe legally able to bump up the TX power, in Aus we can do 1W EIRP for 915-930MHz.
From memory 20 will give you 100mW, 24 gives you just under 400mW and 30 gives you 1W.  Note that I use 24 (400mW output) with antennas with some gain to give me 1W EIRP.  On the land side I'm about to use a high gain antenna on a tracker and will drop it right down to less than 100mW output but the EIRP will be close to 1W.
So no simple answer I'm afraid it depends on the environment you are in.
Thanks for your response Chris.
what configuration should I use in mission planner for good range in a rural area?
Hello, I benn using a pair of these 900+ units with great results, even when I only use one in my Iris+ for Mapping I get a lot more than the normal 3DR Radios can give me, I will love to Beta test any sample, Cristian
I am working on an application for search and rescue where i need to relay telemetry from a low flying (search) vehicle to a high flying (relay) aircraft that re-transmits it to a ground station that is not in line of sight with the low flyer (search) vehicle.  has anyone used these modems for that purpose?  i had planned on using 3dr type transmitters but would rather get the range these seem to offer.
dennis
RFD has a relay system for their modem so as to use one as repeater
Just a random update ! - We have FREE DHL Shipping worldwide for this weekend, ending on Monday for all orders over $100 AUD. Just use the coupon code WOW to enable this :) Wishing all a nice weekend from all here. Seppo
Seppo,
I have a couple questions before ordering. Could please provide me an email? ( I just added you as a friend )
Thanks.
Juan
Any update on RFD900x release date ? or test results ?
Seppo said 1-2 months in May...
