I've had two times now, random, when I am flying in Simple Stabilize and am unable to come out of a roll. For all I know it could happen in pitch as well, but in these two cases it was a roll. The first time this happened I got control back after trying to give it the opposite stick of the roll (it was not immediate though), and was able to land. The last time, not so lucky.
I'm looking for any clues as to why this is happening and how to prevent.
I've attached a log screen shot with notes, as we well as a google map image to help visual the crash.
If needed I can add the logs. I think the that the RollIn values being pegged and flat lined are very odd. Its like the radio was transmitting full roll.
Thanks for any insight you can provide. On a side know there is a Cell tower very close, probably like 100 feet. Any chance this is causing the issue?
Tags:
Post the log, it'd be easier in the long run.
Log added.
Thanks - if you graph RollIn vs Roll, you can see the airframe is responding normally to the commanded roll. I think you're right to be suspicious about the radio. I'm not familiar with that RX - but I don't recall hearing of issues with that and the ArduPPM. Do you have any failsafe configured?
45 members
1472 members
282 members
470 members
57 members
Powered by
