Hi guys,
I'm trying to change the min and max for the tail servo. But I can not do it. The value is returned to the 1500 value.
Please, how to fix it?
Try Full Parameter List/Tree and check RC4 limits
Unfortunately, this parameter does not fit.
Hi Igor,
basically you need to tell the FC the radio range (RC...) and the setup of your helicopter (H....).
'Radio Calibration' sets the RC4 values similar to these:
RC4_DZ,5
RC4_MAX,1934
RC4_MIN,1094
RC4_REV,1
RC4_TRIM,1514
The helicopter specific values start with H(or H_) depending which version you use. In 3.3 you get/set something like:
HS4_MAX,1929
HS4_MIN,1099
HS4_REV,1
HS4_TRIM,1520
You can change all parameters in 'Full Param List/Tree'.
Thanks for the help!
