Hi everyone,
I'm creating this thread to share your drone/copter information. I believe, this would help immensely for newbies like me during the initial build. For example, the Chris's blog on cheap Hobby King quad configuration is really a good resource.
I don't want to burden anyone who is willing to share their info. Hence all fields are optional. Atleast the first 5 fields are ideal. Please find the list of fields to copy/paste at the end, so you can start filling :-).
Here goes information about my quad.
frame: Quadcopter (3DRobotics)
controller/autopilot: APM1
esc: 20A (3DRobotics)
motors: 850Kv (3DRobotics)
propellers: 10x47, APC (3DRobotics)
motor to motor distance: -- inches
battery:  4S 3300mAh (Turnigy nano-tech)
total weight: -- lbs
flying time: 15 minutes (average)
radio: Turnigy 9X
video/osd: none
other: Sonar, Xbee, GPS/Mag, Attopilot current sensor
Misc:
Turnigy 9X: Mode1 -> Mode2 change, Li-ion battery hack
photos:
frame:
esc:
motors:
propellers:
battery:
flying time:
radio:
video/osd:
other:
Misc (hacks/mods):
photos:
To help we will need a lot more info than 'it won't take off'
What motors, batteries, frame weight, props, calibrations done, version of APMCopter, and maybe a photo or 2.
The more info you put in your post the more someone can help.
If you use Static Thrust Calculator
http://personal.osi.hu/fuzesisz/strc_eng/
you can input values for motors and propellers. It will help you calculate the lifting force the motors can manage. With this and the weight of the complete quad you can figure out if it can lift or not.
You'll want a lifting force more than double of the weight of your quad.
By connecting one of the ESCs directly to the receiver you should be able to run the motor manually. This can also help when measuring the force the motor + propeller can give you.
When I calculated my huge octo I fixated one motor on a table and put a scale under the leg of the table. When running the motor at full speed I could see the force difference on the scale.
There are many simple tricks you can do to solve the issue!
Good luck!
Anders
Here is a system I was playing with for now.
It is based on the Armattan FPV v2 TILT frame, about of 350g. 'Tilt' part of the frame was ignored and replaced with a gimbal. Whole frame is a multi-plate carbon fiber construct that is able to survive a nuclear blast, if needed.
Inner frame cage part is mounted on 6 rubber bobbins and vibration isolated, FC sits on additional vibration isolation pad - was probably an overkill but works fine. Total cost of all parts in this pictured setup was under $500 including battery and GoPro, as that was the point - to see what can be done using cheapest parts available on Ebay and a solid indestructible frame.
Propulsion - DJI old red 2212 980kV motors, Mystic SimonK 30A Black ESCs, 9047 props, 5000mAh Turnigy 20C battery.
FC - APM 2.8, GPS/Compass - M8N, Taranis X8R receiver, Teensy 3.1 board for telemetry into X8R.3DR radio telemetry transmitter.
Simple cheap $40 gimbal from Ebay, GoPro 3 White, Boscam TS351.
MinimOSD was taken out due to extreme glitchiness and a practical lack of purpose.
Total armed weight of the build - 1810g, flight time with all systems powered up and GoPro filming - 15m20sec until battery goes to 3.5V per cell from 4.20v initial charge.
Nice Setup, what is the flight time ?
Hello everyone. Newish to this site, been the creepy troll reading all about quads and UAV's etc on this site of awsomeness.
Here is my current quad, tis nothing special. Using this frame because I may have broke the PVC setup I had.
Here's the specs:
Motors: DJI 2212 920kv
Props: Generic 1045 carbon fiber (amazon)
ESC: Generic 20a w/ simonk
Frame: HK Q450 V3 (DJI Knockoff)(very good frame for learning to fly. Actually crashed it and and it rolled across the field like a wheel.)
Flight Control: CC3D (don't judge)
Battery: Turnigy NanoTech 2200 3s 20c
Transmitter: Turnigy 9X v2 flashed with Open 9x and backlight. This made a pretty annoying controller into an extremely useable one. (no smarty parts, was brave and soldered the wires)
Current build  (#2) is a wood hex 550 using pretty much the same hardware except it will have APM 2.6 clone onboard, as I wanted to go more autonomous flight to do fly throughs of completed construction projects. I plan on giving the booms a 4º incline for dihedral for more stability. Yes, probably overkill for flying a go pro around, but I have to convince my wife its not just another toy =)
Hi
Strayed from the DIY approach and decided to buy a frame.  This is the Aeroxcraft 670 quadcopter which is very sturdy and fairly light.
DJI Naza v1 flight controller with GPS
Turnigy plush 30a esc
Eflite 480 motors
HQ 11inch props (very good props)
3s 6000mah lipo (10+ mins flight time)
Quanum Q-3d gimbal with Gopro 3+
I will most likely migrate naza v2 equipment from my scratchbuilt hexacopter into this frame since I prefer its flight
characteristics.
Here is mine:
FRAME: S500 Glass Fiber Quadcopter Frame 480mm - Integrated PCB Version - Weight
FC: HKPilot  Mega 2.7 Master Set
ESC: Q Brain 4x25A Brushless Quadcopter ESC 2-4S 3A SBEC
MOTORS: Turngiy D2836/8 1100KV
PROPS: 10x4.5 SF
BATTERY: Multistar 3S 5200 Mah
TOTAL WEIGHT: 1780g.
FLYING TIME: 7 minutes fully loaded.
RADIO: Turnigy 9XR (with FrSky DF Combo for JR) - Modified as a ground station - See video here :)
VIDEO: SJ4000 + SkyZone TS353 5.8Ghz 400mW FPV Transmitter + SkyZone RC805 -5.8Ghz 8 Channel Receiver + MinimOSD
GIMBAL: 2 axis e-bay gimbal (planing to upgrade to 3 axis goodluckbuy gimbal with storm32 board)
RECORDINGS:
9XR RADIO AS GROUND STATION
FLYING FROM OUTSIDE:
PICTURES:
Happy flying to everyone :)
AlbEagle
love the inspire, I also fly a kraken 1300 octo, TBs discoveries, one with long arms/long range,one with short arms, 3dr x8 mapping ship.
I've been interested in building drones and RC in general since Xmas 2014 when I got a tiny Cheerson CX-10 bought for me as a present. Well, I'm a bit obsessive when it comes to new hobbies, so I ended up doing a lot of studdying on the forums, and built my first drone. It was a:
  • F450 clone frame
  • Sparky v1 FC running cleanflight
  • Turnigy Plush 30a ESCs and Multistar 2213-939kv motors with 9047 APC props
  • 3s lipo
Looked like this initially:
Then I added landing gear and a gimbal:
and switched the configuration around a little, so now the FC was on top and the battery in the middle. I was doing this in readiness for my Pixhawk controller which was on order and knew that the Pixhawk was best isolated and up away from electrical noise etc. Well, the pixhawk (clone) arrived and I then had a bunch of learning to do about APM:
I soon learned that the Turnigy Plush ESCs flashed with BLHeli v12 didn't play well with Pixhawk (it was really random on power up which ESCs would actually initialise - due to new bootloader code in BLHeli), so I switched the ESCs for X-Rotor 25a and it flew quite well with no apparent issues.
Then I crashed! It was actually due to the PosHold doing a flakey and the copter deciding to go off flying by itself in a seemingly random direction! I tried to take control but not before it hit the deck and smasked my landing gear and the fibreglass mounts I had built to retrofit the gear to the F550 frame. So then came a new design idea!
I decided to build on an extra deck to the underside of the quad which would act as both a battery tray for 2x lipos, plus the landing gear mounts. This is what I ended up building:
Then I decided that the extra weight of the 2 x LiPos and this frame would be too much for the wee quad, so decided to go back to the drawing board with a new plan!! So the quad got stripped:
The plan was for more lift, so an extra 2 motors, ESCs and a F550 frame were ordered. I did some calculations and really needed 11" props. I knew the motors and ESCs were capable of pushing 11x47 CF props and providing enough lift for the 2 x 5800mah 3s Lipos along with the 3 axis gimbal and GoPro. I first experimented and ordered extended arms from HK. These were a disaster as they were far too weak - twisted under load, so instead I went for the standard F550 arms with CF extensions to make the hexa a 680mm frame. This is how it turned out:
I managed to crash this one too - it did a flakey on takeoff one day - the APM logs pointed at a failed ESC, and managed to trash the landing gear again, so bought some HK retracts and built new landing gear. One of the HK retracts failed after a few weeks, so I ended up buying yet another set of retracts, this time Tarot ones. These are much nicer and far smoother in operation than any of the previous ones I had. I then set to improving the gimbal mounting, so I could get the gimbal controller mounted more neatly. This is a bunch of pics of what I made and fitting the (X-Cam 3 axis) gimbal to it:
Much tidier job, but within 2 weeks the gibmal went faulty - still waiting for HK to replace it!
Anyway, the hexa flies really well. Its final build spec is this:
  • F550 Frame with extended arms - making 680mm frame
  • Turnigy Multistar 2213-935kv motors
  • Hobbywing 25a X-Rotor ESCs (running stock f/w)
  • 1147 CF props
  • Pixhawk clone running Arducopter 3.2.1
  • 90a Crius APM power module(feeding Volts/Amps to Pixhawk telemetry)
  • UBlox m8n GPS module
  • FrSky X8R Rx
  • Teensy telemetry converter running Wolkstein code and LUA scripts on Taranis Radio
  • MinimOSD
  • 415MHz telemetry radios
  • Tarot small retracts
  • 2 x 5800mah Zippy Compact 25c 3s Lipos
  • 2 x 5000mah Zippy Compact 25c 3s LiPos
  • Custom battery tray/deck allowing 2 of the above LiPos to be slotted in place, with retracts attached plus 12mm gimbal rails and gimbal hanging underneath.
  • PWM->S.Bus converter allowing control of the Gimbal from either the main radio or a slave
  • Boscam 5.8GHz 600mW VTx
Some pics of final build:
After I finished this, I realy got the build bug! I started on my latest build a Tarot 680Pro. That will be another post!
Edit - I finished the tarot build and really this F550 is sitting gathering dust now, so I'm thinking about selling it. Get in touch if you want further info. Even though I have borrowed the telemetry radios from this hexa for the tarot, I have another set on order so it will be sold with 415Mhz telem radios plus the 4 x LiPos mentioned in the list above. The only thing it won't be sold with is the gimbal and associated electronics.
Hi Group,
I admit, I am a new and a complete novice re RC and  UAV, drones et al.
Reading a lot about drones, following all the internet discussions
 and rc groups, I finally committed myself :)
I am technically/electronic-minded-abled person though :)
Herewith a summary of my components I have selected for my Quad Build
Air Frame : Tarot 650 Sport with Electric Landing Gear
Motor : Tarot 4114 KV320
ESC : HobbyWing Xrotor 40A
Prop : 15.55" Foxtec Brand
FC : Pixhawk (incl GPS, minimOSD, 433 telem etc)
Radio : FrSky X9D + (Taranis)  > Mode 2   Receiver : X8R
Gimbal : X-CAM 3-AX
Cam 1 : FHD Tube cam for FPV
Cam 2 : GoPro Silver 4 recording
Vid TX : 5.8Ghz 600mW
Ground Station : Diversity 7"  with DVR function
Batt : 6S 8000 25C  >>  Zippy, Gens Ace, Tattu, Turnigy nano ??  Any good??
(Power Module can handle up 30Vin,
   with the corresponding V/I monitor values to interface with the PixHawk)
Application : Aerial Vid/Photo hobby interest
I will post pics once constructed.
On completing the construction,
 I want to venture into configuring the X9D for the Quad.
Prior to doing  any Flight configurations with the X9D,
 my first attempt will be to configure the X9D to operate the Electric Landing Gear (ELG)
To boost my confidence?? :)
My thinking here is >>
 To configure the X9D to operate the ELG,
I assume one select a switch eg SF, which is  On/Off operation
 opposed to SH which is  Momentary?
 (Or should one use a Momentary >SH< for ELG operation,    I think not)
iow > using SF in one direction ELG retract (for flying), SF in other position ELG extend (for landing)
How do one configure that on the X9D, assuming assigning CH8 on X8R rcvr for ELG operation?
If someone has done likewise and is prepared to share their knowledge, I will appreciate it.
I have looked at many build-vids/how-to vids/ to broadening my knowledge,
 to date I have been unable to find info to help me implement this basic function.
Any vid-links etc that you can point to will help me, I think.....
I realize with this question it shows my novice approach and newby status,
BUT if I can configure the X9D to perform this elementary Function,
  see the ELG operating,   it will put a BIG smile on my old whaSog!!....
Thank you once again for your valuable and knowledgable feedback.
Gerhard
I don't have that radio but here you can see my Tarot if you want to take ideas http://diydrones.com/forum/topics/my-second-cuad-a-tarot-650 I'm not an expert but if I can help with another thing, I do it ;)
Here is my second custom quadcopter.  It's designed to give the head tracking gimbal the best view so I added retractable skids.
  • Pixhawk APM
  • SkyIII 30A 4 in 1 ESC
  • Tiger MN4012 Kv340 Motors
  • Maxamps 11000mAh LiPo Battery
  • Immersion RC 5.8 Ghz Video Tx
  • GoPro Hero 3+ Black
  • DYS Brushless Gimbal
  • Lemon Rx DSMX Compatible PPM 8­Channel Receiver + Lemon DSMX
  • Custom water jet cut carbon fiber and CNC'ed aluminum
Weight 10lb
28.4" prop center to prop center
The bare frame with retractable landing gear is 736g.
40min endurance
