Simple RF Data link for GPS data
Guys I am a complete newbie so excuse the obvious questions.
I fly fullsize and also large scale gliders and there are a few steps on this path but can I start with the simple one please.
Can someone guide me on setting up a simple RF downlink to send GPS data from the scale aircraft to the ground and displaying the realtime position of the glider on a tablet or smartphone please?
I have looked at 3DR Compact 915MHz 500mw Bluetooth Box Radio Telemetry Module. Will this work? Can I connect a GPS without the Autopilot gear?
  • Take a look here: http://forum.ausrocketry.com/viewtopic.php?f=32&t=5240
    This uses 3DR radios direct to GPS module, should do what you want it to.
  • Rob, first check uCenter with direct connection to GPS unit, if this will sufficient for you. Than you can use radio link to connect this unit remotely.
  • Yes still looking for a solution. And a software solution too.
    A bit more on the application itself. This is not an autopilot application (but it might take on elements of this later). Glider racing involves flying a glider around a usually triangular course with the RC pilot doing the flying without assistance so the idea is to transmit the GPS data to a display that is with the pilot guiding him/her from waypoint to waypoint.
  • I've tested it before, both with NMEA and proprietary uBlox binary protocol - all works fine if you'll set correct baud for radio link.
    But the question was asked over a half year ago and I'm not sure if is still valid...
  • Simple but worth considering :-)
    PS. Pls, "Martin", not "Marvin" ;-)
  • He can connect i.e. M8N GPS receiver via radio link to PC running uCenter and control position from ground.
