Hi Forum members- seeking help on this subject.
Seeking a multi-copter UAV for surveillance in a gated community.  As our guards need to operate it has to be very simple to operate. features
GPS pre defined route (autonomously) pre-programmed
Return to home (low bat, etc) and land / power down
Live stream Camera / camera mount (thermal preferred, night vision up to 30 meters)
Very simple start / stop operation (Will not be flown manually once routes pre- programmed)
The distance is quite large  1.35 km from take off point, although the drone would follow roads so flight time is relatively short.
Have you tried getting in touch with any UAV Companies to see if they can help? I would recommend SUAS Global info@suas-global.com hope this helps.
