I'm considering using a smartphone to take a series of aerial photos from an APM controlled fixed wing aircraft before stitching them together with something like AgiSoft.
The benefits of smart phones versus a compact camera that I can see are.
1. Smaller and lighter
2. Cheaper
3. Can be programmed
4. Inbuilt GPS
There are some good camera apps that allow shutter speed control with a timed continuous shooting mode.
Does anyone have experience or any insight into trying this?
Tags:
My insight would be to backup your contacts before throwing your phone into the air. ;)
Spag?,
I gave up on trying to trigger any camera from the APM. It became simpler and easier just to set whatever camera you are using to a 3 second interval and let it go. With the capacity of SD cards these days, it is easier to delete the photos you don't want.
Does this help you or are you trying to do something different?
Where are you located?
Jerry
spagoziak said:
I see this thread is almost 5 years old... has anyone else made progress on this? I'd like to use my S9 as a camera, but I'd like it to receive commands from APM, probably via an app. This doesn't seem so exotic an idea now, but I can't find much evidence online that anyone has done this yet.
spag
Heya Jerry,
You're probably right. I'm up in Minnesota. The more I look around, the more obvious it gets that brute force will have to do. It's a shame that this route eliminates much of the intelligence that the APM team wrote in for this very purpose.
True; but with the APM there is so much going on it is good to just set the thing going and not have to worry about it till after the flight.
What are you flying?
spagoziak said:
Heya Jerry,
I'm currently offline for a rebuild; the airframe is a skywalker (6 foot foam pusher). I'm migrating APM from the old APM 2.6 legacy hardware to a Beaglebone blue. Quite a learning curve!
Good luck; please post some pictures.
45 members
1472 members
282 members
470 members
57 members
Powered by
