Telemetry Connect Problem In Mission Planner
Hi all -
I recently had a GPS issue with my quadcopter that almost flew away when I switched on the autopilot to fly a waypoint mission - successfully brought it back manually and a review of the logs suggested some sort of GPS glitch. So I decided that in the future, I would take a laptop with me to the field and monitor telemetry.
I have a telemetry transceiver that connects to a USB but needed a laptop, so I bought a used Dell Inspiron 14 from a neighbor, loaded Mission Planner and installed the Silicon Labs driver - Mission Planner sees COM Port 3. However, when I attempt to connect to my aircraft the connection fails with an error that says the maximum baud rate for "the device" is 8190. I know that the transceiver works okay as I can plug it into my desktop and it connects just fine to my aircraft.
This Dell laptop has two USB 3.0 and one USB 2.0 port; it doesn't matter which port I use as I get the same error.
Has anyone seen this problem? I am using the same version of Mission Planner on both computers - desktop works fine.
  • RESOLVED!   After reviewing my results I decided that the problem was the Silicon Labs driver I was using. So I uninstalled the driver and downloaded an FTDI driver from the Dell download page and installed, rebooted the Dell..... It works - Mission Planner is now connecting to the radio.
  • Addendum: I can connect to my aircraft by plugging a USB cable from the APM to the laptop - M.P. sees COM4, which I used and it connected just fine even though it connected at a higher baud rate. I've attached a screen snippet of the error.
DIY Robocars via Twitter
Nov 27, 2022
Nov 24, 2022
Nov 24, 2022
Nov 24, 2022
Nov 24, 2022
Nov 20, 2022
Nov 20, 2022
Nov 8, 2022
Nov 8, 2022
Oct 23, 2022
Oct 23, 2022
Oct 23, 2022
Oct 19, 2022
Oct 18, 2022
Oct 13, 2022
RT @araffin2: 🏎️ After hours of video editing, I'm happy to share a best of my Twitch videos on learning to race with RL. 🏎️ Each part is…
Oct 13, 2022
