TPS79133DBVR equivalent
I have a APM 2.5.2 (From 3DRobotics) with a burned out TPS79133DBVR 3.3v regulator.
But I live in Brazil and I could not find this component here, to buy from the USA it would be too expensive (almost US$ 100 with shipment and taxes......)
But searching for orher 3.3 100mA with a 5-Pin SOT23 (DBV) Package I could find the TPS76933.
Is that regulator a good substitute for the TPS79133?
Thank you.
  • Hi Bruno,
    Open farnell.com and search for LDO, then select 3.3V and all fields from 100 to 250mA + the SOT-23/5 case field.
    You'll see a lot of compattible LDOs. Then check those with pin1 = IN, pin2 = GND, pin3=EN, pin 4 = bypass capacitor, pin5=OUT. That's it.
    Cheers!
    Nick
    • That is how I found the  TPS76933!!
      3702510656?profile=original
      • The only problem I see with TPS79133 is that EN is low level signal, in opposite to most other LDOs which have EN=high. You need to check the PCB layout for to see whether the EN is tied to VCC or to GND, then to choose the appropriate LDO.
        • The TPS76933 is EN=Low
          The main difference is that it does not have the BP and have a simpler inner schematics - but at least I could find it to buy around here.
Abdulatif Tlaib liked Ryan's profile
8 hours ago
DIY Robocars via Twitter
RT @SmallpixelCar: First time at @wsraceways. After tuning @HokuyoUsa lidar signal and camera sensor on @NVIDIAEmbedded, my car was able to…
Sunday
RT @breadcentric: The handy bit about racing with self-driving cars is that one can type while the car is racing. Report from #AWSDeepRacer…
Jun 18
RT @chr1sa: Our Bay Area @DIYRobocars meetup is now at 2,700 members. Next in-person events (in Oakland) are training day on July 17 and…
Jun 18
Videos from the ICRA autonomous racing workshop are now available: https://linklab-uva.github.io/icra-autonomous-racing/
Jun 10
RT @SmallpixelCar: Prepared race track for Warm Spring Raceways @wsraceways and looking forward to test my new car at RAMS RC @ramsaicar fa…
Jun 6
RT @f1tenth: Trying out some nasty blocking maneuvers 🏎️🤖 #f1tenth #autonomousracing https://t.co/nMTstsaogM
Jun 5
May 27
RT @araffin2: I will talk this Saturday from 18:00 to 19:00 Paris time for the @diyrobocars community about learning to race in hours using…
May 27
RT @a1k0n: Luckily the infeasible hairpin problem was easily reproducible in simulation and I could test the fix before bringing the car ba…
May 26
RT @a1k0n: Another problem was that I was over-constraining the car's allowed accelerations, so it didn't think it could turn as tight as i…
May 26
RT @a1k0n: Breaking the map up into two halves worked, but I had to be more careful about separating the inner track from outer. There's se…
May 26
RT @a1k0n: Here's a datalog for my fastest lap of the day. Lap timer is tiny window lower-left. https://t.co/myrlWWrKUY
May 26
May 26
RT @a1k0n: Here was my car's POV. Man this track is confusing in first-person! After the incident my camera was all scuffed up and I was af…
May 23
RT @circuitlaunch: Loved seeing so many familiar (masked) faces at Circuit Launch today for our first in person @diyrobocars in over a year…
May 22
