So I'm having some problems setting up my tricopter. When I increase the throttle the yaw is also affected. The back motor begins to turn left or right. It will stay spinning in the same direction unless I touch the yaw stick on my controller. I'm using the KK2.1.5 board brand new and Turnigy 9x controller. In the first video you can see on the controller that i have slightly trimmed the yaw if I didn't do that then it wouldn't be level . Even if i zeroed the yaw trim it would still yaw uncontrollably. First post please be gentle :)
ps sorry for the poor cable management I have mesh but haven't bother to put it on. :P
bump
This isn't really a KK kind of place Tegan. Do you have a throttle rudder mix programmed in the radio? Is the tail servo slightly tilted at the start, ie not straight up. It should be tilted slightly. Looking at the video things don't look to bad, rather try and fly in a bigger area though.
