I have been trying to get 2.9 to build so I can beta test and I cannot get it to compile. I have followed the Wiki and other instructions, but when I try to build I get a huge list of errors - most of which appear to be around variable declarations. It looks to me like it maybe it is not finding the libraries. This is the directory structure I have:
My Documents
     ArduPilot-Arduino-1.0.3-windows
     ardupilot-mega-9235ce36ede9
          ArducCopter
              all the source code
          libraries
              all the library files
I run Arduino (as Administrator, just in case), set the ardupilot-mega-9235ce36ede9 folder as the sketchbook folder and open Arducopter/ArduCopter.pde from there. This opens all the various files into tabs in the editor.
If I click the Verify button, I get several hundred errors (see below) - this feels like I am missing some simple step - but I am darned if I know what it might be. HELP!
Log:1190: error: 'data' was not declared in this scope
Log:1193: error: 'log_step' was not declared in this scope
Parameters.pde: In function 'void load_parameters()':
Parameters:672: error: 'micros' was not declared in this scope
commands.pde: In function 'void set_cmd_with_index(Location, int)':
commands:74: error: 'constrain' was not declared in this scope
commands.pde: In function 'int32_t get_RTL_alt()':
commands:111: error: 'min' was not declared in this scope
commands:113: error: 'min' was not declared in this scope
commands.pde: In function 'void set_next_WP(Location*)':
commands:156: error: 'max' was not declared in this scope
commands.pde: In function 'void init_home()':
commands:196: error: 'Log_Write_Cmd' was not declared in this scope
commands_logic.pde: In function 'void do_RTL()':
commands_logic:230: error: 'wp_control' was not declared in this scope
commands_logic.pde: In function 'void do_takeoff()':
commands_logic:246: error: 'wp_control' was not declared in this scope
commands_logic.pde: In function 'void do_nav_wp()':
commands_logic:264: error: 'wp_control' was not declared in this scope
commands_logic.pde: In function 'void do_land()':
commands_logic:293: error: 'wp_control' was not declared in this scope
commands_logic.pde: In function 'void do_loiter_unlimited()':
commands_logic:300: error: 'wp_control' was not declared in this scope
commands_logic.pde: In function 'void do_loiter_turns()':
commands_logic:315: error: 'wp_control' was not declared in this scope
commands_logic.pde: In function 'void do_loiter_time()':
commands_logic:342: error: 'wp_control' was not declared in this scope
commands_logic:343: error: 'millis' was not declared in this scope
commands_logic:346: error: 'wp_control' was not declared in this scope
commands_logic.pde: In function 'bool verify_nav_wp()':
commands_logic:395: error: 'millis' was not declared in this scope
commands_logic:405: error: 'wp_control' was not declared in this scope
commands_logic:407: error: 'millis' was not declared in this scope
commands_logic.pde: In function 'bool verify_loiter_unlimited()':
commands_logic:426: error: 'wp_control' was not declared in this scope
commands_logic.pde: In function 'bool verify_loiter_time()':
commands_logic:436: error: 'wp_control' was not declared in this scope
commands_logic:437: error: 'millis' was not declared in this scope
commands_logic:441: error: 'wp_control' was not declared in this scope
commands_logic:443: error: 'millis' was not declared in this scope
commands_logic.pde: In function 'bool verify_RTL()':
commands_logic:485: error: 'wp_control' was not declared in this scope
commands_logic:499: error: 'wp_control' was not declared in this scope
commands_logic:502: error: 'millis' was not declared in this scope
commands_logic:511: error: 'millis' was not declared in this scope
commands_logic:536: error: 'set_mode' was not declared in this scope
commands_logic.pde: In function 'void do_wait_delay()':
commands_logic:568: error: 'millis' was not declared in this scope
commands_logic.pde: In function 'void do_yaw()':
commands_logic:604: error: 'constrain' was not declared in this scope
commands_logic.pde: In function 'bool verify_wait_delay()':
commands_logic:622: error: 'millis' was not declared in this scope
commands_logic.pde: In function 'void do_repeat_servo()':
commands_logic:815: error: 'event_id' was not declared in this scope
commands_logic.pde: In function 'void do_repeat_relay()':
commands_logic:844: error: 'event_id' was not declared in this scope
commands_process.pde: In function 'void change_command(uint8_t)':
commands_process:9: error: 'min' was not declared in this scope
commands_process.pde: In function 'void execute_nav_command()':
commands_process:159: error: 'Log_Write_Cmd' was not declared in this scope
commands_process.pde: In function 'void exit_mission()':
commands_process:223: error: 'set_mode' was not declared in this scope
commands_process:225: error: 'set_mode' was not declared in this scope
control_modes.pde: In function 'void read_control_switch()':
control_modes:8: error: 'byte' was not declared in this scope
control_modes:8: error: expected `;' before 'switchPosition'
control_modes:10: error: 'oldSwitchPosition' was not declared in this scope
control_modes:10: error: 'switchPosition' was not declared in this scope
control_modes:18: error: 'set_mode' was not declared in this scope
control_modes.pde: At global scope:
control_modes:34: error: 'byte' does not name a type
control_modes.pde: In function 'void reset_control_switch()':
control_modes:47: error: 'oldSwitchPosition' was not declared in this scope
control_modes.pde: In function 'void read_trim_switch()':
control_modes:93: error: 'set_mode' was not declared in this scope
control_modes:116: error: 'set_mode' was not declared in this scope
control_modes:142: error: 'constrain' was not declared in this scope
control_modes.pde: In function 'void auto_trim()':
control_modes:187: error: 'led_mode' was not declared in this scope
events.pde: In function 'void failsafe_on_event()':
events:25: error: 'set_mode' was not declared in this scope
events:28: error: 'set_mode' was not declared in this scope
events:35: error: 'set_mode' was not declared in this scope
events:38: error: 'set_mode' was not declared in this scope
events:45: error: 'set_mode' was not declared in this scope
events:48: error: 'set_mode' was not declared in this scope
events.pde: In function 'void low_battery_event()':
events:76: error: 'set_mode' was not declared in this scope
events:81: error: 'set_mode' was not declared in this scope
events:84: error: 'set_mode' was not declared in this scope
events:88: error: 'set_mode' was not declared in this scope
events:101: error: 'bitRead' was not declared in this scope
events.pde: In function 'void update_events()':
events:110: error: 'millis' was not declared in this scope
events:114: error: 'millis' was not declared in this scope
events:116: error: 'event_id' was not declared in this scope
events:124: error: 'event_id' was not declared in this scope
failsafe.pde: In function 'void failsafe_enable()':
failsafe:20: error: 'micros' was not declared in this scope
leds.pde: In function 'void update_lights()':
leds:5: error: 'led_mode' was not declared in this scope
leds.pde: In function 'void update_GPS_light()':
leds:25: error: 'HIGH' was not declared in this scope
leds:25: error: 'bitWrite' was not declared in this scope
leds:25: error: 'digitalWrite' was not declared in this scope
leds:27: error: 'LOW' was not declared in this scope
leds:27: error: 'bitWrite' was not declared in this scope
leds:27: error: 'digitalWrite' was not declared in this scope
leds:35: error: 'LOW' was not declared in this scope
leds:35: error: 'bitWrite' was not declared in this scope
leds:35: error: 'digitalWrite' was not declared in this scope
leds:37: error: 'HIGH' was not declared in this scope
leds:37: error: 'bitWrite' was not declared in this scope
leds:37: error: 'digitalWrite' was not declared in this scope
leds:44: error: 'LOW' was not declared in this scope
leds:44: error: 'bitWrite' was not declared in this scope
leds:44: error: 'digitalWrite' was not declared in this scope
leds.pde: In function 'void update_motor_light()':
leds:56: error: 'HIGH' was not declared in this scope
leds:56: error: 'bitWrite' was not declared in this scope
leds:56: error: 'digitalWrite' was not declared in this scope
leds:58: error: 'LOW' was not declared in this scope
leds:58: error: 'bitWrite' was not declared in this scope
leds:58: error: 'digitalWrite' was not declared in this scope
leds:63: error: 'HIGH' was not declared in this scope
leds:63: error: 'bitWrite' was not declared in this scope
leds:63: error: 'digitalWrite' was not declared in this scope
leds.pde: In function 'void dancing_light()':
leds:70: error: 'byte' does not name a type
leds:72: error: 'step' was not declared in this scope
leds:75: error: 'step' was not declared in this scope
leds:78: error: 'LOW' was not declared in this scope
leds:78: error: 'bitWrite' was not declared in this scope
leds:78: error: 'digitalWrite' was not declared in this scope
leds:79: error: 'HIGH' was not declared in this scope
leds:79: error: 'bitWrite' was not declared in this scope
leds:79: error: 'digitalWrite' was not declared in this scope
leds:83: error: 'LOW' was not declared in this scope
leds:83: error: 'bitWrite' was not declared in this scope
leds:83: error: 'digitalWrite' was not declared in this scope
leds:84: error: 'HIGH' was not declared in this scope
leds:84: error: 'bitWrite' was not declared in this scope
leds:84: error: 'digitalWrite' was not declared in this scope
leds:88: error: 'LOW' was not declared in this scope
leds:88: error: 'bitWrite' was not declared in this scope
leds:88: error: 'digitalWrite' was not declared in this scope
leds:89: error: 'HIGH' was not declared in this scope
leds:89: error: 'bitWrite' was not declared in this scope
leds:89: error: 'digitalWrite' was not declared in this scope
leds.pde: In function 'void clear_leds()':
leds:95: error: 'LOW' was not declared in this scope
leds:95: error: 'bitWrite' was not declared in this scope
leds:95: error: 'digitalWrite' was not declared in this scope
leds:96: error: 'LOW' was not declared in this scope
leds:96: error: 'bitWrite' was not declared in this scope
leds:96: error: 'digitalWrite' was not declared in this scope
leds:97: error: 'LOW' was not declared in this scope
leds:97: error: 'bitWrite' was not declared in this scope
leds:97: error: 'digitalWrite' was not declared in this scope
leds:99: error: 'led_mode' was not declared in this scope
leds.pde: In function 'void update_copter_leds()':
leds:129: error: 'bitRead' was not declared in this scope
leds:151: error: 'bitRead' was not declared in this scope
leds:185: error: 'bitRead' was not declared in this scope
leds.pde: In function 'void copter_leds_reset()':
leds:196: error: 'LOW' was not declared in this scope
leds:196: error: 'bitWrite' was not declared in this scope
leds:196: error: 'digitalWrite' was not declared in this scope
leds:197: error: 'LOW' was not declared in this scope
leds:197: error: 'bitWrite' was not declared in this scope
leds:197: error: 'digitalWrite' was not declared in this scope
leds:198: error: 'LOW' was not declared in this scope
leds:198: error: 'bitWrite' was not declared in this scope
leds:198: error: 'digitalWrite' was not declared in this scope
leds:199: error: 'LOW' was not declared in this scope
leds:199: error: 'bitWrite' was not declared in this scope
leds:199: error: 'digitalWrite' was not declared in this scope
leds:200: error: 'LOW' was not declared in this scope
leds:200: error: 'bitWrite' was not declared in this scope
leds:200: error: 'digitalWrite' was not declared in this scope
leds:201: error: 'LOW' was not declared in this scope
leds:201: error: 'bitWrite' was not declared in this scope
leds:201: error: 'digitalWrite' was not declared in this scope
leds:202: error: 'LOW' was not declared in this scope
leds:202: error: 'bitWrite' was not declared in this scope
leds:202: error: 'digitalWrite' was not declared in this scope
leds:203: error: 'LOW' was not declared in this scope
leds:203: error: 'bitWrite' was not declared in this scope
leds:203: error: 'digitalWrite' was not declared in this scope
leds.pde: In function 'void copter_leds_on()':
leds:207: error: 'bitRead' was not declared in this scope
leds:208: error: 'HIGH' was not declared in this scope
leds:208: error: 'bitWrite' was not declared in this scope
leds:208: error: 'digitalWrite' was not declared in this scope
leds:215: error: 'HIGH' was not declared in this scope
leds:215: error: 'bitWrite' was not declared in this scope
leds:215: error: 'digitalWrite' was not declared in this scope
leds:217: error: 'bitRead' was not declared in this scope
leds:218: error: 'HIGH' was not declared in this scope
leds:218: error: 'bitWrite' was not declared in this scope
leds:218: error: 'digitalWrite' was not declared in this scope
leds:220: error: 'HIGH' was not declared in this scope
leds:220: error: 'bitWrite' was not declared in this scope
leds:220: error: 'digitalWrite' was not declared in this scope
leds:221: error: 'HIGH' was not declared in this scope
leds:221: error: 'bitWrite' was not declared in this scope
leds:221: error: 'digitalWrite' was not declared in this scope
leds:222: error: 'HIGH' was not declared in this scope
leds:222: error: 'bitWrite' was not declared in this scope
leds:222: error: 'digitalWrite' was not declared in this scope
leds:223: error: 'HIGH' was not declared in this scope
leds:223: error: 'bitWrite' was not declared in this scope
leds:223: error: 'digitalWrite' was not declared in this scope
leds:224: error: 'HIGH' was not declared in this scope
leds:224: error: 'bitWrite' was not declared in this scope
leds:224: error: 'digitalWrite' was not declared in this scope
leds.pde: In function 'void copter_leds_off()':
leds:228: error: 'bitRead' was not declared in this scope
leds:229: error: 'LOW' was not declared in this scope
leds:229: error: 'bitWrite' was not declared in this scope
leds:229: error: 'digitalWrite' was not declared in this scope
leds:236: error: 'LOW' was not declared in this scope
leds:236: error: 'bitWrite' was not declared in this scope
leds:236: error: 'digitalWrite' was not declared in this scope
leds:238: error: 'bitRead' was not declared in this scope
leds:239: error: 'LOW' was not declared in this scope
leds:239: error: 'bitWrite' was not declared in this scope
leds:239: error: 'digitalWrite' was not declared in this scope
leds:241: error: 'LOW' was not declared in this scope
leds:241: error: 'bitWrite' was not declared in this scope
leds:241: error: 'digitalWrite' was not declared in this scope
leds:242: error: 'LOW' was not declared in this scope
leds:242: error: 'bitWrite' was not declared in this scope
leds:242: error: 'digitalWrite' was not declared in this scope
leds:243: error: 'LOW' was not declared in this scope
leds:243: error: 'bitWrite' was not declared in this scope
leds:243: error: 'digitalWrite' was not declared in this scope
leds:244: error: 'LOW' was not declared in this scope
leds:244: error: 'bitWrite' was not declared in this scope
leds:244: error: 'digitalWrite' was not declared in this scope
leds:245: error: 'LOW' was not declared in this scope
leds:245: error: 'bitWrite' was not declared in this scope
leds:245: error: 'digitalWrite' was not declared in this scope
leds.pde: In function 'void copter_leds_slow_blink()':
leds:249: error: 'copter_leds_motor_blink' was not declared in this scope
leds:252: error: 'bitRead' was not declared in this scope
leds.pde: In function 'void copter_leds_fast_blink()':
leds:262: error: 'copter_leds_motor_blink' was not declared in this scope
leds.pde: In function 'void copter_leds_oscillate()':
leds:273: error: 'copter_leds_motor_blink' was not declared in this scope
leds:275: error: 'bitRead' was not declared in this scope
leds:276: error: 'HIGH' was not declared in this scope
leds:276: error: 'bitWrite' was not declared in this scope
leds:276: error: 'digitalWrite' was not declared in this scope
leds:283: error: 'HIGH' was not declared in this scope
leds:283: error: 'bitWrite' was not declared in this scope
leds:283: error: 'digitalWrite' was not declared in this scope
leds:285: error: 'bitRead' was not declared in this scope
leds:286: error: 'LOW' was not declared in this scope
leds:286: error: 'bitWrite' was not declared in this scope
leds:286: error: 'digitalWrite' was not declared in this scope
leds:288: error: 'LOW' was not declared in this scope
leds:288: error: 'bitWrite' was not declared in this scope
leds:288: error: 'digitalWrite' was not declared in this scope
leds:289: error: 'HIGH' was not declared in this scope
leds:289: error: 'bitWrite' was not declared in this scope
leds:289: error: 'digitalWrite' was not declared in this scope
leds:290: error: 'HIGH' was not declared in this scope
leds:290: error: 'bitWrite' was not declared in this scope
leds:290: error: 'digitalWrite' was not declared in this scope
leds:291: error: 'LOW' was not declared in this scope
leds:291: error: 'bitWrite' was not declared in this scope
leds:291: error: 'digitalWrite' was not declared in this scope
leds:292: error: 'LOW' was not declared in this scope
leds:292: error: 'bitWrite' was not declared in this scope
leds:292: error: 'digitalWrite' was not declared in this scope
leds:294: error: 'bitRead' was not declared in this scope
leds:295: error: 'LOW' was not declared in this scope
leds:295: error: 'bitWrite' was not declared in this scope
leds:295: error: 'digitalWrite' was not declared in this scope
leds:302: error: 'LOW' was not declared in this scope
leds:302: error: 'bitWrite' was not declared in this scope
leds:302: error: 'digitalWrite' was not declared in this scope
leds:304: error: 'bitRead' was not declared in this scope
leds:305: error: 'HIGH' was not declared in this scope
leds:305: error: 'bitWrite' was not declared in this scope
leds:305: error: 'digitalWrite' was not declared in this scope
leds:307: error: 'HIGH' was not declared in this scope
leds:307: error: 'bitWrite' was not declared in this scope
leds:307: error: 'digitalWrite' was not declared in this scope
leds:308: error: 'LOW' was not declared in this scope
leds:308: error: 'bitWrite' was not declared in this scope
leds:308: error: 'digitalWrite' was not declared in this scope
leds:309: error: 'LOW' was not declared in this scope
leds:309: error: 'bitWrite' was not declared in this scope
leds:309: error: 'digitalWrite' was not declared in this scope
leds:310: error: 'HIGH' was not declared in this scope
leds:310: error: 'bitWrite' was not declared in this scope
leds:310: error: 'digitalWrite' was not declared in this scope
leds:311: error: 'HIGH' was not declared in this scope
leds:311: error: 'bitWrite' was not declared in this scope
leds:311: error: 'digitalWrite' was not declared in this scope
leds.pde: In function 'void copter_leds_GPS_on()':
leds:319: error: 'HIGH' was not declared in this scope
leds:319: error: 'bitWrite' was not declared in this scope
leds:319: error: 'digitalWrite' was not declared in this scope
leds.pde: In function 'void copter_leds_GPS_off()':
leds:323: error: 'LOW' was not declared in this scope
leds:323: error: 'bitWrite' was not declared in this scope
leds:323: error: 'digitalWrite' was not declared in this scope
leds.pde: In function 'void copter_leds_GPS_slow_blink()':
leds:327: error: 'copter_leds_GPS_blink' was not declared in this scope
leds:330: error: 'bitRead' was not declared in this scope
leds.pde: In function 'void copter_leds_GPS_fast_blink()':
leds:340: error: 'copter_leds_GPS_blink' was not declared in this scope
leds.pde: In function 'void copter_leds_aux_off()':
leds:350: error: 'LOW' was not declared in this scope
leds:350: error: 'bitWrite' was not declared in this scope
leds:350: error: 'digitalWrite' was not declared in this scope
leds.pde: In function 'void copter_leds_aux_on()':
leds:354: error: 'HIGH' was not declared in this scope
leds:354: error: 'bitWrite' was not declared in this scope
leds:354: error: 'digitalWrite' was not declared in this scope
leds.pde: In function 'void piezo_on()':
leds:358: error: 'HIGH' was not declared in this scope
leds:358: error: 'bitWrite' was not declared in this scope
leds:358: error: 'digitalWrite' was not declared in this scope
leds.pde: In function 'void piezo_off()':
leds:362: error: 'LOW' was not declared in this scope
leds:362: error: 'bitWrite' was not declared in this scope
leds:362: error: 'digitalWrite' was not declared in this scope
leds.pde: In function 'void piezo_beep()':
leds:367: error: 'delay' was not declared in this scope
limits.pde: In function 'void limits_loop()':
limits:53: error: 'millis' was not declared in this scope
limits:129: error: 'millis' was not declared in this scope
limits:140: error: 'millis' was not declared in this scope
limits:173: error: 'millis' was not declared in this scope
limits:195: error: 'class AP_Limits' has no member named 'old_mode_switch'
limits:195: error: 'oldSwitchPosition' was not declared in this scope
limits:196: error: 'class AP_Limits' has no member named 'old_mode_switch'
limits:216: error: 'millis' was not declared in this scope
limits:229: error: 'class AP_Limits' has no member named 'old_mode_switch'
limits:229: error: 'oldSwitchPosition' was not declared in this scope
limits:259: error: 'set_mode' was not declared in this scope
limits:260: error: 'millis' was not declared in this scope
limits:286: error: 'millis' was not declared in this scope
limits:288: error: 'set_mode' was not declared in this scope
limits:297: error: 'millis' was not declared in this scope
limits:301: error: 'set_mode' was not declared in this scope
limits:324: error: 'millis' was not declared in this scope
limits:331: error: 'set_mode' was not declared in this scope
limits.pde: In function 'void limits_send_mavlink_status(mavlink_channel_t)':
limits:347: error: 'millis' was not declared in this scope
motors.pde: In function 'void init_arm_motors()':
motors:123: error: 'bitRead' was not declared in this scope
motors:125: error: 'delay' was not declared in this scope
motors:157: error: 'HIGH' was not declared in this scope
motors:157: error: 'digitalWrite' was not declared in this scope
motors.pde: In function 'void init_disarm_motors()':
motors:198: error: 'bitRead' was not declared in this scope
navigation.pde: In function 'void update_navigation()':
navigation:16: error: 'millis' was not declared in this scope
navigation:20: error: 'min' was not declared in this scope
navigation:66: error: 'millis' was not declared in this scope
navigation.pde: In function 'void run_navigation_contollers()':
navigation:184: error: 'set_mode' was not declared in this scope
navigation:242: error: 'wp_control' was not declared in this scope
navigation:253: error: 'wp_control' was not declared in this scope
navigation:268: error: 'wp_control' was not declared in this scope
navigation.pde: In function 'void update_nav_wp()':
navigation:297: error: 'wp_control' was not declared in this scope
navigation:360: error: 'constrain' was not declared in this scope
navigation.pde: In function 'void calc_loiter(int16_t, int16_t)':
navigation:480: error: 'constrain' was not declared in this scope
navigation.pde: In function 'void calc_nav_rate(int16_t)':
navigation:545: error: 'constrain' was not declared in this scope
navigation.pde: In function 'int16_t get_desired_speed(int16_t)':
navigation:616: error: 'min' was not declared in this scope
navigation:620: error: 'min' was not declared in this scope
navigation:621: error: 'max' was not declared in this scope
navigation.pde: In function 'int32_t get_yaw_slew(int32_t, int32_t, int16_t)':
navigation:735: error: 'constrain' was not declared in this scope
radio.pde: In function 'void init_rc_out()':
radio:71: error: 'byte' was not declared in this scope
radio:71: error: expected `;' before 'i'
radio:71: error: 'i' was not declared in this scope
radio:72: error: 'delay' was not declared in this scope
radio:95: error: 'delay' was not declared in this scope
radio.pde: In function 'void read_radio()':
radio:146: error: 'min' was not declared in this scope
radio:150: error: 'millis' was not declared in this scope
radio.pde: In function 'void trim_radio()':
radio:203: error: 'byte' was not declared in this scope
radio:203: error: expected `;' before 'i'
radio:203: error: 'i' was not declared in this scope
sensors.pde: In function 'void read_receiver_rssi()':
sensors:144: error: 'constrain' was not declared in this scope
setup.pde: In function 'int8_t setup_mode(uint8_t, const Menu::arg*)':
setup:72: error: 'delay' was not declared in this scope
setup.pde: In function 'int8_t setup_factory(uint8_t, const Menu::arg*)':
setup:133: error: 'delay' was not declared in this scope
setup.pde: In function 'int8_t setup_radio(uint8_t, const Menu::arg*)':
setup:151: error: 'delay' was not declared in this scope
setup:158: error: 'delay' was not declared in this scope
setup:194: error: 'delay' was not declared in this scope
setup.pde: In function 'int8_t setup_motors(uint8_t, const Menu::arg*)':
setup:237: error: 'delay' was not declared in this scope
setup.pde: In function 'int8_t setup_accel(uint8_t, const Menu::arg*)':
setup:252: error: 'delay' was not declared in this scope
setup.pde: In function 'void setup_printf_P(const prog_char_t*, ...)':
setup:267: error: invalid conversion from 'void*' to 'int'
setup:267: error: initializing argument 2 of 'void BetterStream::vprintf_P(const prog_char_t*, int)'
setup.pde: In function 'void setup_wait_key()':
setup:275: error: 'delay' was not declared in this scope
setup.pde: In function 'int8_t setup_accel_scale(uint8_t, const Menu::arg*)':
setup:290: error: 'delay' was not declared in this scope
setup.pde: In function 'int8_t setup_flightmodes(uint8_t, const Menu::arg*)':
setup:320: error: 'byte' was not declared in this scope
setup:320: error: expected `;' before '_switchPosition'
setup:321: error: expected `;' before '_oldSwitchPosition'
setup:328: error: 'delay' was not declared in this scope
setup:330: error: '_switchPosition' was not declared in this scope
setup:330: error: 'readSwitch' was not declared in this scope
setup:334: error: '_oldSwitchPosition' was not declared in this scope
setup:337: error: 'constrain' was not declared in this scope
setup:340: error: 'print_switch' was not declared in this scope
setup:356: error: 'print_switch' was not declared in this scope
setup:364: error: 'print_switch' was not declared in this scope
setup:372: error: 'print_switch' was not declared in this scope
setup.pde: In function 'int8_t setup_declination(uint8_t, const Menu::arg*)':
setup:392: error: 'radians' was not declared in this scope
setup.pde: At global scope:
setup:784: error: variable or field 'report_wp' declared void
setup:784: error: 'byte' was not declared in this scope
ArduCopter.pde:204: warning: 'int16_t get_heli_rate_roll(int32_t)' declared 'static' but never defined
ArduCopter.pde:206: warning: 'int16_t get_heli_rate_pitch(int32_t)' declared 'static' but never defined
ArduCopter.pde:208: warning: 'int16_t get_heli_rate_yaw(int32_t)' declared 'static' but never defined
ArduCopter.pde:258: warning: 'void send_simstate(mavlink_channel_t)' declared 'static' but never defined
GCS_Mavlink.pde:2107: warning: 'void gcs_send_text(gcs_severity, const char*)' defined but not used
Log.pde:873: warning: 'void Log_Write_Startup()' defined but not used
Log.pde:904: warning: 'void Log_Write_Data(uint8_t, float)' defined but not used
Log.pde:915: warning: 'void Log_Write_Data(uint8_t, int16_t)' defined but not used
Log.pde:1016: warning: 'void Log_Write_DMP()' defined but not used
Parameters.pde:633: warning: 'void load_parameters()' defined but not used
leds.pde:93: warning: 'void clear_leds()' defined but not used
navigation.pde:646: warning: 'void force_new_altitude(int32_t)' defined but not used
radio.pde:21: warning: 'void init_rc_in()' defined but not used
radio.pde:61: warning: 'void init_rc_out()' defined but not used
sensors.pde:6: warning: 'void ReadSCP1000()' defined but not used
sensors.pde:10: warning: 'void init_sonar()' defined but not used
ArduCopter.pde:498: warning: 'void report_sonar()' declared 'static' but never defined
ArduCopter.pde:499: warning: 'void report_frame()' declared 'static' but never defined
ArduCopter.pde:500: warning: 'void report_radio()' declared 'static' but never defined
ArduCopter.pde:501: warning: 'void report_ins()' declared 'static' but never defined
ArduCopter.pde:502: warning: 'void report_compass()' declared 'static' but never defined
ArduCopter.pde:503: warning: 'void report_flight_modes()' declared 'static' but never defined
ArduCopter.pde:505: warning: 'void report_heli()' declared 'static' but never defined
ArduCopter.pde:506: warning: 'void report_gyro()' declared 'static' but never defined
ArduCopter.pde:508: warning: 'void print_radio_values()' declared 'static' but never defined
ArduCopter.pde:512: warning: 'void print_done()' declared 'static' but never defined
ArduCopter.pde:513: warning: 'void zero_eeprom()' declared 'static' but never defined
ArduCopter.pde:515: warning: 'void print_accel_offsets_and_scaling()' declared 'static' but never defined
ArduCopter.pde:517: warning: 'void print_gyro_offsets()' declared 'static' but never defined
ArduCopter.pde:519: warning: 'RC_Channel* heli_get_servo(int16_t)' declared 'static' but never defined
ArduCopter.pde:520: warning: 'int16_t read_num_from_serial()' declared 'static' but never defined
ArduCopter.pde:522: warning: 'void print_blanks(int16_t)' declared 'static' but never defined
ArduCopter.pde:524: warning: 'void print_divider()' declared 'static' but never defined
ArduCopter.pde:525: warning: 'void print_enabled(bool)' declared 'static' but never defined
ArduCopter.pde:527: warning: 'void init_esc()' declared 'static' but never defined
ArduCopter.pde:528: warning: 'void print_wp(Location*, int)' declared 'static' but never defined
ArduCopter.pde:529: warning: 'void report_version()' declared 'static' but never defined
ArduCopter.pde:530: warning: 'void report_tuning()' declared 'static' but never defined
ArduCopter.pde:531: warning: 'void run_cli(FastSerial*)' declared 'static' but never defined
ArduCopter.pde:532: warning: 'void init_ardupilot()' declared 'static' but never defined
ArduCopter.pde:533: warning: 'void startup_ground()' declared 'static' but never defined
ArduCopter.pde:536: warning: 'void init_simple_bearing()' declared 'static' but never defined
ArduCopter.pde:539: warning: 'uint32_t map_baudrate(int8_t, uint32_t)' declared 'static' but never defined
ArduCopter.pde:540: warning: 'void check_usb_mux()' declared 'static' but never defined
ArduCopter.pde:543: warning: 'void reboot_apm()' declared 'static' but never defined
ArduCopter.pde:545: warning: 'void print_flight_mode(uint8_t)' declared 'static' but never defined
ArduCopter.pde:546: warning: 'void print_hit_enter()' declared 'static' but never defined
ArduCopter.pde:547: warning: 'void print_test_disabled()' declared 'static' but never defined
ArduCopter.pde:673: warning: 'climb_rate_actual' defined but not used
ArduCopter.pde:675: warning: 'climb_rate_error' defined but not used
ArduCopter.pde:688: warning: 'saved_toy_throttle' defined but not used
ArduCopter.pde:798: warning: 'yaw_timer' defined but not used
Log.pde:223: warning: 'int8_t process_logs(uint8_t, const Menu::arg*)' defined but not used
setup.pde:61: warning: 'int8_t setup_mode(uint8_t, const Menu::arg*)' defined but not used
Oh right, understood.
Another Arduino lesson learned :-)
Still getting errors after,
Copied the libraries folder from 2.9\libraries to the ardunio 1.03 APM version.
Dunno if it matters but I copied the folder as opposed to just the files within it?
Checked the sketch folder and changed it from 2.9rc5 (which is what I was playing with origianlly) to 2.9
Restarted the IDE,
Loaded the arducopter.pde and after sketch----->compile, there were still many errors only this time they referred to the 2.9 folder instead of the 2.9rc5
In file included from C:\Users\User\Downloads\Arducopter\ArduCopter-2.9\libraries\FastSerial/FastSerial.h:56,
                 from ArduCopter.pde:66:
C:\Users\User\Downloads\Arducopter\ArduCopter-2.9\libraries\FastSerial/BetterStream.h:14:20: warning: Stream.h: No such file or directory
In file included from C:\Users\User\Downloads\Arducopter\ArduCopter-2.9\libraries\FastSerial/BetterStream.h:16,
C:\Users\User\Downloads\Arducopter\ArduCopter-2.9\libraries\FastSerial/../AP_Common/AP_Common.h:20:22: error: Arduino.h: No such file or directory
ArduCopter.pde:73:51: warning: SPI.h: No such file or directory
C:\Users\User\Downloads\Arducopter\ArduCopter-2.9\libraries\FastSerial/BetterStream.h:18: error: expected class-name before '{' token
C:\Users\User\Downloads\Arducopter\ArduCopter-2.9\libraries\FastSerial/BetterStream.h:30: error: 'va_list' has not been declared
C:\Users\User\Downloads\Arducopter\ArduCopter-2.9\libraries\FastSerial/BetterStream.h:37: error: 'va_list' has not been declared
In file included from ArduCopter.pde:66:
C:\Users\User\Downloads\Arducopter\ArduCopter-2.9\libraries\FastSerial/FastSerial.h:125: error: no members matching 'BetterStream::write' in 'class BetterStream'
In file included from C:\Users\User\Downloads\Arducopter\ArduCopter-2.9\libraries\AP_GPS/AP_GPS_NMEA.h:45,
                 from C:\Users\User\Downloads\Arducopter\ArduCopter-2.9\libraries\AP_GPS/AP_GPS.h:6,
                 from ArduCopter.pde:71:
C:\Users\User\Downloads\Arducopter\ArduCopter-2.9\libraries\AP_GPS/GPS.h:153: error: ISO C++ forbids declaration of 'Stream' with no type
C:\Users\User\Downloads\Arducopter\ArduCopter-2.9\libraries\AP_GPS/GPS.h:153: error: expected ';' before '*' token
C:\Users\User\Downloads\Arducopter\ArduCopter-2.9\libraries\AP_GPS/GPS.h:162: error: expected `)' before '*' token
C:\Users\User\Downloads\Arducopter\ArduCopter-2.9\libraries\AP_GPS/GPS.h:205: error: 'Stream' has not been declared
C:\Users\User\Downloads\Arducopter\ArduCopter-2.9\libraries\AP_GPS/GPS.h:206: error: 'Stream' has not been declared
In file included from C:\Users\User\Downloads\Arducopter\ArduCopter-2.9\libraries\AP_GPS/AP_GPS.h:6,
C:\Users\User\Downloads\Arducopter\ArduCopter-2.9\libraries\AP_GPS/AP_GPS_NMEA.h:56: error: expected `)' before '*' token
In file included from C:\Users\User\Downloads\Arducopter\ArduCopter-2.9\libraries\AP_GPS/AP_GPS.h:7,
C:\Users\User\Downloads\Arducopter\ArduCopter-2.9\libraries\AP_GPS/AP_GPS_SIRF.h:20: error: expected `)' before '*' token
In file included from C:\Users\User\Downloads\Arducopter\ArduCopter-2.9\libraries\AP_GPS/AP_GPS.h:8,
C:\Users\User\Downloads\Arducopter\ArduCopter-2.9\libraries\AP_GPS/AP_GPS_406.h:23: error: expected `)' before '*' token
In file included from C:\Users\User\Downloads\Arducopter\ArduCopter-2.9\libraries\AP_GPS/AP_GPS.h:9,
C:\Users\User\Downloads\Arducopter\ArduCopter-2.9\libraries\AP_GPS/AP_GPS_UBLOX.h:30: error: expected `)' before '*' token
In file included from C:\Users\User\Downloads\Arducopter\ArduCopter-2.9\libraries\AP_GPS/AP_GPS.h:10,
C:\Users\User\Downloads\Arducopter\ArduCopter-2.9\libraries\AP_GPS/AP_GPS_MTK.h:23: error: expected `)' before '*' token
In file included from C:\Users\User\Downloads\Arducopter\ArduCopter-2.9\libraries\AP_GPS/AP_GPS.h:11,
C:\Users\User\Downloads\Arducopter\ArduCopter-2.9\libraries\AP_GPS/AP_GPS_MTK19.h:25: error: expected `)' before '*' token
In file included from C:\Users\User\Downloads\Arducopter\ArduCopter-2.9\libraries\AP_GPS/AP_GPS.h:12,
C:\Users\User\Downloads\Arducopter\ArduCopter-2.9\libraries\AP_GPS/AP_GPS_None.h:11: error: expected `)' before '*' token
In file included from C:\Users\User\Downloads\Arducopter\ArduCopter-2.9\libraries\AP_GPS/AP_GPS.h:14,
C:\Users\User\Downloads\Arducopter\ArduCopter-2.9\libraries\AP_GPS/AP_GPS_HIL.h:19: error: expected `)' before '*' token
In file included from C:\Users\User\Downloads\Arducopter\ArduCopter-2.9\libraries\AP_GPS/AP_GPS.h:15,
C:\Users\User\Downloads\Arducopter\ArduCopter-2.9\libraries\AP_GPS/AP_GPS_Shim.h: In constructor 'AP_GPS_Shim::AP_GPS_Shim()':
C:\Users\User\Downloads\Arducopter\ArduCopter-2.9\libraries\AP_GPS/AP_GPS_Shim.h:20: error: no matching function for call to 'GPS::GPS(NULL)'
C:\Users\User\Downloads\Arducopter\ArduCopter-2.9\libraries\AP_GPS/GPS.h:16: note: candidates are: GPS::GPS()
C:\Users\User\Downloads\Arducopter\ArduCopter-2.9\libraries\AP_GPS/GPS.h:16: note:                 GPS::GPS(const GPS&)
In file included from C:\Users\User\Downloads\Arducopter\ArduCopter-2.9\libraries\AP_GPS/AP_GPS.h:16,
C:\Users\User\Downloads\Arducopter\ArduCopter-2.9\libraries\AP_GPS/AP_GPS_IMU.h: At global scope:
C:\Users\User\Downloads\Arducopter\ArduCopter-2.9\libraries\AP_GPS/AP_GPS_IMU.h:13: error: expected `)' before '*' token
In file included from ArduCopter.pde:72:
C:\Users\User\Downloads\Arducopter\ArduCopter-2.9\libraries\I2C/I2C.h:74: error: 'boolean' has not been declared
C:\Users\User\Downloads\Arducopter\ArduCopter-2.9\libraries\I2C/I2C.h:75: error: 'boolean' has not been declared
C:\Users\User\Downloads\Arducopter\ArduCopter-2.9\libraries\I2C/I2C.h:106: error: 'boolean' has not been declared
In file included from ArduCopter.pde:74:
C:\Users\User\Downloads\Arducopter\ArduCopter-2.9\libraries\SPI3/SPI3.h:56: error: 'byte' has not been declared
In file included from C:\Users\User\Downloads\Arducopter\ArduCopter-2.9\libraries\AP_Compass/AP_Compass.h:6,
                 from ArduCopter.pde:80:
C:\Users\User\Downloads\Arducopter\ArduCopter-2.9\libraries\AP_Compass/AP_Compass_HMC5843.h:56: error: 'byte' has not been declared
In file included from ArduCopter.pde:82:
C:\Users\User\Downloads\Arducopter\ArduCopter-2.9\libraries\AP_Common/AP_Curve.h: In member function 'virtual void AP_Curve<T, SIZE>::dump_curve()':
C:\Users\User\Downloads\Arducopter\ArduCopter-2.9\libraries\AP_Common/AP_Curve.h:135: error: 'class FastSerial' has no member named 'print'
C:\Users\User\Downloads\Arducopter\ArduCopter-2.9\libraries\AP_Common/AP_Curve.h:137: error: 'class FastSerial' has no member named 'print'
C:\Users\User\Downloads\Arducopter\ArduCopter-2.9\libraries\AP_Common/AP_Curve.h:139: error: 'class FastSerial' has no member named 'print'
C:\Users\User\Downloads\Arducopter\ArduCopter-2.9\libraries\AP_Common/AP_Curve.h:140: error: 'class FastSerial' has no member named 'println'
In file included from ArduCopter.pde:101:
C:\Users\User\Downloads\Arducopter\ArduCopter-2.9\libraries\AP_OpticalFlow/AP_OpticalFlow.h: At global scope:
C:\Users\User\Downloads\Arducopter\ArduCopter-2.9\libraries\AP_OpticalFlow/AP_OpticalFlow.h:54: error: 'byte' does not name a type
C:\Users\User\Downloads\Arducopter\ArduCopter-2.9\libraries\AP_OpticalFlow/AP_OpticalFlow.h:55: error: 'byte' has not been declared
In file included from C:\Users\User\Downloads\Arducopter\ArduCopter-2.9\libraries\AP_Camera/AP_Camera.h:10,
                 from ArduCopter.pde:109:
C:\Users\User\Downloads\Arducopter\ArduCopter-2.9\libraries\GCS_MAVLink/GCS_MAVLink.h: In function 'void comm_send_ch(mavlink_channel_t, uint8_t)':
C:\Users\User\Downloads\Arducopter\ArduCopter-2.9\libraries\GCS_MAVLink/GCS_MAVLink.h:52: error: 'class BetterStream' has no member named 'write'
C:\Users\User\Downloads\Arducopter\ArduCopter-2.9\libraries\GCS_MAVLink/GCS_MAVLink.h:55: error: 'class BetterStream' has no member named 'write'
C:\Users\User\Downloads\Arducopter\ArduCopter-2.9\libraries\GCS_MAVLink/GCS_MAVLink.h: In function 'uint8_t comm_receive_ch(mavlink_channel_t)':
C:\Users\User\Downloads\Arducopter\ArduCopter-2.9\libraries\GCS_MAVLink/GCS_MAVLink.h:73: error: 'class BetterStream' has no member named 'read'
C:\Users\User\Downloads\Arducopter\ArduCopter-2.9\libraries\GCS_MAVLink/GCS_MAVLink.h:76: error: 'class BetterStream' has no member named 'read'
C:\Users\User\Downloads\Arducopter\ArduCopter-2.9\libraries\GCS_MAVLink/GCS_MAVLink.h: In function 'uint16_t comm_get_available(mavlink_channel_t)':
C:\Users\User\Downloads\Arducopter\ArduCopter-2.9\libraries\GCS_MAVLink/GCS_MAVLink.h:93: error: 'class BetterStream' has no member named 'available'
C:\Users\User\Downloads\Arducopter\ArduCopter-2.9\libraries\GCS_MAVLink/GCS_MAVLink.h:96: error: 'class BetterStream' has no member named 'available'
In file included from ArduCopter.pde:130:
C:\Users\User\Downloads\Arducopter\ArduCopter-2.9\libraries\AP_Limits/AP_Limits.h: At global scope:
C:\Users\User\Downloads\Arducopter\ArduCopter-2.9\libraries\AP_Limits/AP_Limits.h:78: error: 'byte' does not name a type
ArduCopter:306: error: variable or field 'Log_Write_Cmd' declared void
ArduCopter:306: error: 'byte' was not declared in this scope
ArduCopter:306: error: expected primary-expression before 'struct'
ArduCopter:312: error: variable or field 'Log_Write_Mode' declared void
ArduCopter:312: error: 'byte' was not declared in this scope
ArduCopter:335: error: variable or field 'Log_Write_Cmd' declared void
ArduCopter:335: error: 'byte' was not declared in this scope
ArduCopter:335: error: expected primary-expression before 'struct'
ArduCopter:336: error: variable or field 'Log_Write_Mode' declared void
ArduCopter:336: error: 'byte' was not declared in this scope
ArduCopter:411: error: 'byte' does not name a type
ArduCopter:512: error: variable or field 'print_switch' declared void
ArduCopter:512: error: 'byte' was not declared in this scope
ArduCopter:512: error: expected primary-expression before 'bool'
ArduCopter:530: error: 'byte' has not been declared
ArduCopter:536: error: variable or field 'set_mode' declared void
ArduCopter:536: error: 'byte' was not declared in this scope
ArduCopter:539: error: 'boolean' does not name a type
ArduCopter:441: error: 'byte' does not name a type
ArduCopter:496: error: 'byte' does not name a type
ArduCopter:498: error: 'byte' does not name a type
ArduCopter:500: error: 'byte' does not name a type
ArduCopter:541: error: 'byte' does not name a type
ArduCopter:815: error: 'byte' does not name a type
ArduCopter:863: error: 'byte' does not name a type
ArduCopter:865: error: 'byte' does not name a type
ArduCopter:867: error: 'byte' does not name a type
ArduCopter.pde: In function 'void loop()':
ArduCopter:945: error: 'micros' was not declared in this scope
ArduCopter:997: error: 'counter_one_herz' was not declared in this scope
ArduCopter.pde: In function 'void medium_loop()':
ArduCopter:1089: error: 'medium_loopCounter' was not declared in this scope
ArduCopter.pde: In function 'void slow_loop()':
ArduCopter:1265: error: 'slow_loopCounter' was not declared in this scope
ArduCopter.pde: In function 'void update_GPS()':
ArduCopter:1394: error: 'byte' does not name a type
ArduCopter:1412: error: 'ground_start_count' was not declared in this scope
ArduCopter.pde: In function 'void update_roll_pitch_mode()':
ArduCopter:1674: error: 'constrain' was not declared in this scope
ArduCopter.pde: In function 'void update_simple_mode()':
ArduCopter:1732: error: 'byte' does not name a type
ArduCopter:1737: error: 'simple_counter' was not declared in this scope
ArduCopter:1743: error: 'radians' was not declared in this scope
ArduCopter:1747: error: 'radians' was not declared in this scope
ArduCopter.pde: In function 'void update_trig()':
ArduCopter:2013: error: 'constrain' was not declared in this scope
ArduCopter.pde: In function 'void update_altitude()':
ArduCopter:2056: error: 'constrain' was not declared in this scope
Attitude.pde: In function 'void get_stabilize_roll(int32_t)':
Attitude:10: error: 'constrain' was not declared in this scope
Attitude.pde: In function 'void get_stabilize_pitch(int32_t)':
Attitude:34: error: 'constrain' was not declared in this scope
Attitude.pde: In function 'void get_stabilize_yaw(int32_t)':
Attitude:63: error: 'constrain' was not declared in this scope
Attitude.pde: In function 'void get_roll_rate_stabilized_ef(int32_t)':
Attitude:133: error: 'constrain' was not declared in this scope
Attitude:138: error: 'constrain' was not declared in this scope
Attitude.pde: In function 'void get_pitch_rate_stabilized_ef(int32_t)':
Attitude:169: error: 'constrain' was not declared in this scope
Attitude:174: error: 'constrain' was not declared in this scope
Attitude.pde: In function 'void get_yaw_rate_stabilized_ef(int32_t)':
Attitude:206: error: 'constrain' was not declared in this scope
Attitude.pde: In function 'int16_t get_rate_roll(int32_t)':
Attitude:472: error: 'constrain' was not declared in this scope
Attitude.pde: In function 'int16_t get_rate_pitch(int32_t)':
Attitude:513: error: 'constrain' was not declared in this scope
Attitude.pde: In function 'int16_t get_rate_yaw(int32_t)':
Attitude:549: error: 'constrain' was not declared in this scope
Attitude.pde: In function 'int32_t get_of_roll(int32_t)':
Attitude:606: error: 'constrain' was not declared in this scope
Attitude:621: error: 'constrain' was not declared in this scope
Attitude.pde: In function 'int32_t get_of_pitch(int32_t)':
Attitude:660: error: 'constrain' was not declared in this scope
Attitude:673: error: 'constrain' was not declared in this scope
Attitude.pde: In function 'int16_t get_angle_boost(int16_t)':
Attitude:739: error: 'constrain' was not declared in this scope
Attitude:740: error: 'max' was not declared in this scope
Attitude.pde: In function 'int16_t get_throttle_accel(int16_t)':
Attitude:794: error: 'millis' was not declared in this scope
Attitude:805: error: 'constrain' was not declared in this scope
Attitude:821: error: 'constrain' was not declared in this scope
Attitude.pde: In function 'int16_t get_pilot_desired_climb_rate(int16_t)':
Attitude:854: error: 'constrain' was not declared in this scope
Attitude.pde: In function 'int16_t get_pilot_desired_acceleration(int16_t)':
Attitude:887: error: 'constrain' was not declared in this scope
Attitude.pde: In function 'int32_t get_pilot_desired_direct_alt(int16_t)':
Attitude:916: error: 'constrain' was not declared in this scope
Attitude.pde: In function 'void get_throttle_rate(int16_t)':
Attitude:932: error: 'millis' was not declared in this scope
Attitude.pde: In function 'void get_throttle_althold(int32_t, int16_t, int16_t)':
Attitude:1011: error: 'constrain' was not declared in this scope
Attitude.pde: In function 'void get_throttle_althold_with_slew(int16_t, int16_t, int16_t)':
Attitude:1028: error: 'constrain' was not declared in this scope
Attitude.pde: In function 'void get_throttle_rate_stabilized(int16_t)':
Attitude:1045: error: 'constrain' was not declared in this scope
Attitude.pde: In function 'void get_throttle_surface_tracking(int16_t)':
Attitude:1093: error: 'millis' was not declared in this scope
Attitude:1104: error: 'constrain' was not declared in this scope
GCS_Mavlink.pde: In function 'bool gcs_check()':
GCS_Mavlink:29: error: 'millis' was not declared in this scope
GCS_Mavlink.pde: In function 'void send_attitude(mavlink_channel_t)':
GCS_Mavlink:114: error: 'millis' was not declared in this scope
GCS_Mavlink.pde: In function 'void send_location(mavlink_channel_t)':
GCS_Mavlink:238: error: 'millis' was not declared in this scope
GCS_Mavlink.pde: In function 'void send_servo_out(mavlink_channel_t)':
GCS_Mavlink:378: error: 'millis' was not declared in this scope
GCS_Mavlink.pde: In function 'void send_radio_in(mavlink_channel_t)':
GCS_Mavlink:397: error: 'millis' was not declared in this scope
GCS_Mavlink.pde: In function 'void send_radio_out(mavlink_channel_t)':
GCS_Mavlink:414: error: 'micros' was not declared in this scope
GCS_Mavlink.pde: In function 'void send_raw_imu1(mavlink_channel_t)':
GCS_Mavlink:444: error: 'micros' was not declared in this scope
GCS_Mavlink.pde: In function 'void send_raw_imu2(mavlink_channel_t)':
GCS_Mavlink:460: error: 'millis' was not declared in this scope
GCS_Mavlink.pde: In function 'bool telemetry_delayed(mavlink_channel_t)':
GCS_Mavlink:505: error: 'millis' was not declared in this scope
GCS_Mavlink.pde: In member function 'void GCS_MAVLINK::update()':
GCS_Mavlink:832: error: 'millis' was not declared in this scope
GCS_Mavlink.pde: In member function 'void GCS_MAVLINK::handleMessage(mavlink_message_t*)':
GCS_Mavlink:1069: error: 'set_mode' was not declared in this scope
GCS_Mavlink:1166: error: 'set_mode' was not declared in this scope
GCS_Mavlink:1199: error: 'millis' was not declared in this scope
GCS_Mavlink:1330: error: 'millis' was not declared in this scope
GCS_Mavlink:1452: error: 'millis' was not declared in this scope
GCS_Mavlink:1590: error: 'set_mode' was not declared in this scope
GCS_Mavlink:1630: error: 'millis' was not declared in this scope
GCS_Mavlink:1690: error: 'constrain' was not declared in this scope
GCS_Mavlink:1698: error: 'constrain' was not declared in this scope
GCS_Mavlink:1706: error: 'constrain' was not declared in this scope
GCS_Mavlink.pde: In function 'void mavlink_delay(long unsigned int)':
GCS_Mavlink:2056: error: 'delay' was not declared in this scope
GCS_Mavlink:2062: error: 'millis' was not declared in this scope
GCS_Mavlink:2067: error: 'delayMicroseconds' was not declared in this scope
GCS_Mavlink.pde: In function 'void gcs_send_text_fmt(const prog_char_t*, ...)':
GCS_Mavlink:2134: error: 'va_list' was not declared in this scope
GCS_Mavlink:2134: error: expected `;' before 'arg_list'
GCS_Mavlink:2142: error: 'arg_list' was not declared in this scope
GCS_Mavlink:2142: error: 'va_start' was not declared in this scope
GCS_Mavlink:2143: error: 'vsnprintf' was not declared in this scope
GCS_Mavlink:2144: error: 'va_end' was not declared in this scope
Log.pde: In function 'bool print_log_menu()':
Log:94: error: 'class FastSerial' has no member named 'println'
Log:111: error: 'class FastSerial' has no member named 'println'
Log.pde: In function 'void Log_Read_Raw()':
Log:333: error: 'class FastSerial' has no member named 'print'
Log.pde: In function 'void Log_Read_Iterm()':
Log:666: error: 'class FastSerial' has no member named 'println'
Log.pde: At global scope:
Log:706: error: variable or field 'Log_Write_Cmd' declared void
Log:706: error: 'byte' was not declared in this scope
Log:706: error: expected primary-expression before 'struct'
Log:854: error: variable or field 'Log_Write_Mode' declared void
Log:854: error: 'byte' was not declared in this scope
Log.pde: In function 'int16_t Log_Read_Process(int16_t, int16_t)':
Log:1186: error: 'byte' was not declared in this scope
Log:1186: error: expected `;' before 'data'
Log:1187: error: expected `;' before 'log_step'
Log:1195: error: 'data' was not declared in this scope
Log:1198: error: 'log_step' was not declared in this scope
commands:151: error: 'max' was not declared in this scope
commands:188: error: 'Log_Write_Cmd' was not declared in this scope
commands_logic:229: error: 'wp_control' was not declared in this scope
commands_logic:245: error: 'wp_control' was not declared in this scope
commands_logic:266: error: 'wp_control' was not declared in this scope
commands_logic:295: error: 'wp_control' was not declared in this scope
commands_logic:305: error: 'wp_control' was not declared in this scope
commands_logic:320: error: 'wp_control' was not declared in this scope
commands_logic:347: error: 'wp_control' was not declared in this scope
commands_logic:348: error: 'millis' was not declared in this scope
commands_logic:351: error: 'wp_control' was not declared in this scope
commands_logic:400: error: 'millis' was not declared in this scope
commands_logic:410: error: 'wp_control' was not declared in this scope
commands_logic:412: error: 'millis' was not declared in this scope
commands_logic:431: error: 'wp_control' was not declared in this scope
commands_logic:442: error: 'millis' was not declared in this scope
commands_logic:446: error: 'wp_control' was not declared in this scope
commands_logic:448: error: 'millis' was not declared in this scope
commands_logic:490: error: 'wp_control' was not declared in this scope
commands_logic:504: error: 'wp_control' was not declared in this scope
commands_logic:507: error: 'millis' was not declared in this scope
commands_logic:516: error: 'millis' was not declared in this scope
commands_logic:541: error: 'set_mode' was not declared in this scope
commands_logic:573: error: 'millis' was not declared in this scope
commands_logic:609: error: 'constrain' was not declared in this scope
commands_logic:627: error: 'millis' was not declared in this scope
commands_logic:820: error: 'event_id' was not declared in this scope
commands_logic:849: error: 'event_id' was not declared in this scope
control_modes:192: error: 'led_mode' was not declared in this scope
Thats as much as I could paste into my reply :-)
Any ideas?
D
I'm just uploading a short vid of what I'm actually doing to youtube at the minute,
I'll link to it as soon as it's available.
Thanks again for the help
D
See earlier in this thread: a lot of people are not getting successful builds using the ArduPilot build of Arduino. I had the same problem.
Using the 1.0.3 standard build from the Arduino site worked for me.
Hi David,
After much experimentation I've discovered that I can use the 1.0.3 standard build from the Arduino site on my work desktop and on my laptop and they both compile sucessfully but I cannot get my desktop to work properly without errors.
I had a similar issue with the APM, it would work ok on the lappy but not on the desktop.
Luckily the lappy is also the GCS so it'll do fine!
Thanks again for your help!
D
I've found what is causing the problem. Screen size!......
Put a complete arducopter code and compiler installation on a network drive Had it setup so the libraries were found, went to compile, and had the problems being outlined here.
Screamed multiple times, and tried lots of variations. Still problems.
Could compile sample files, add libraries to these, and they worked, but the full code wouldn't.
Then happened to try it from another computer with a 'full size' screen (2560*1600), and the same setup worked.
Resized the display down to the same size as my laptop screen, and the compile failed.
When running on a screen smaller than about 1000 lines vertically, the list under 'libraries' is truncated, only showing about 90% of the ones the compiler knows about. When this happens, you can't scroll the list to show the missing items, and according to which ones are missing off the screen, you get one of the various compile errors being shown. You can actually change the error by rearranging which ones are on the screen.
It appears the compiler only searches in the libraries that are in the list it shows on the screen.
The standard builds seem not to behave quite the same in this regard.
A real 'cracker' of a fault.
I'm also having the same problem with apm version 3.2.1 but didn't get any solution to this problem........
I get a lot of errors and I did all of the suggestions from this page but I couldn't solve the problem. Could you please help me?
