Hello,
First if this is posted in the wrong place feel free to redirect me to a better forum.
I've been following this tutorial.  I've got a FTDI cable connected as described (without the +5v connected) and that seems to be working.  I've set the baud rate as described.  When I get to the section to enter the command "mavproxy.py --master=/dev/ttyUSB0 --baudrate 1500000 --aircraft MyCopter" here is what is shown through the terminal:
odroid@odroid:~$ mavproxy.py --master=/dev/ttyUSB0 --baudrate 1500000 --aircraft MyCopter
Connect /dev/ttyUSB0 source_system=255
no script MyCopter/mavinit.scr
Log Directory: MyCopter/logs/2016-01-25/flight6
Telemetry log: MyCopter/logs/2016-01-25/flight6/flight.tlog
MAV> Waiting for heartbeat from /dev/ttyUSB0
fence breach
online system 1
STABILIZE> Mode STABILIZE
APM: PX4v2 002E0027 35324716 36343032
Flight battery 100 percent
Received 377 parameters
Saved 377 parameters to MyCopter/logs/2016-01-25/flight6/mav.parm
Process Process-1:
Traceback (most recent call last):
 File "/usr/lib/python2.7/multiprocessing/process.py", line 258, in _bootstrap
   self.run()
 File "/usr/lib/python2.7/multiprocessing/process.py", line 114, in run
   self._target(*self._args, **self._kwargs)
 File "/usr/local/lib/python2.7/dist-packages/MAVProxy/modules/mavproxy_map/srtm.py", line 128, in createFileListHTTP
   conn.request("GET",self.directory)
 File "/usr/lib/python2.7/httplib.py", line 1052, in request
   self._send_request(method, url, body, headers)
 File "/usr/lib/python2.7/httplib.py", line 1092, in _send_request
   self.endheaders(body)
 File "/usr/lib/python2.7/httplib.py", line 1048, in endheaders
   self._send_output(message_body)
 File "/usr/lib/python2.7/httplib.py", line 892, in _send_output
   self.send(msg)
 File "/usr/lib/python2.7/httplib.py", line 854, in send
   self.connect()
 File "/usr/lib/python2.7/httplib.py", line 831, in connect
   self.timeout, self.source_address)
 File "/usr/lib/python2.7/socket.py", line 557, in create_connection
   for res in getaddrinfo(host, port, 0, SOCK_STREAM):
gaierror: [Errno -3] Temporary failure in name resolution
Could it be that I missed something while installing the packages listed in the tutorial?
Any help would be greatly appreciated!
Loren
Hi Loren, it seems that initially it works well (otherwise you wouldn't get parameters, heartbeat, and mode). Are you running Ubuntu 14.04?
Yes I believe so
It's failing to resolve the DNS name to get the terrain data.
what version of MAVProxy are you using and ArduPilot?
mavproxy --version
I connected the Odroid to a network that had internet connectivity today and it worked.  Do I need to have access to the internet for my Odroid to run mavproxy properly?  Or did I misunderstand the DNS issue?
MAV Proxy should fail gracefully, but it doesn't. (bug)Copter doesn't use terrain following yet.
Try making sure TERRAIN_ENABLE is set to 0 in the FW so it does't make a request for the data. http://copter.ardupilot.com/wiki/arducopter-parameters/#terrain_dat...
And feel a bug against MAV Proxy
