  • This is the backup battery which allows the module memory to be saved. When you have the backup battery you will begin with a hot start (or warm start depending on how long it's been) instead of a cold start. A hot start will give you a position fix in 1s, and a cold start would be 30s-120s. After the time to first fix the positioning performance will be the same.
    Sounds like Dave is on to something with checking if the battery leads are shorting out if the battery on your board is rechargeable.
  • No i wont cause a problem. It will just take it longer to get a gps fix. Check the legs on the battery soldered to the board. Mine were shorted together when they soldered it to the board. I had to remove the cell and solder it back to the board then it startrd to work.
  • My 6m had a rechargable battery in it. It would go flat but when it was plugged in for a while it would recharge. I tested it with a meter.
    • Can it cause problems if it won't charge and you still fly
  • The battery is a ms621 battery
DIY Robocars via Twitter
May 15
May 14
May 13
May 13
May 11
May 8
May 8
RT @SmallpixelCar: Test my car. RTK GPS worked great. Thanks @emlid for their support. https://t.co/EkQ6qmjmWR
May 8
DIY Drones via Twitter
RT @chr1sa: @kane That's @diydrones circa 2009. Still have a box of those Canon cameras that we used to strap into planes, just like this.…
May 3
RT @chr1sa: Our next @diyrobocars race is going to be outside at a real RC racetrack in Fremont on May 28. Fully autonomous racing, head-to…
Apr 30
RT @f1tenth: Our Spring 2022 F1TENTH course @PennEngineers is coming to an end with a head-to-head race as a big finale. So proud of our st…
Apr 26
RT @DanielChiaJH: I wrote a thing! Throughout the development of my @diyrobocars car I've been using @foxglovedev Studio to visualize and d…
Apr 23
RT @SmallpixelCar: My new car for high speed. Low body, everything ( @NVIDIAEmbedded Jetson Xavier NX, @emlid RTK GPS, IMC) under the deck…
Apr 23
Apr 21
RT @f1tenth: F1TENTH Race training setup @PennEngineers for our upcoming ICRA2022 @ieee_ras_icra competition. @OpenRoboticsOrg @IndyAChalle…
Apr 21
RT @fatcatFABLAB: Proud to be hosting a restarted DIY Robocars NYC Meetup April 26. Come by if you want to talk about and race self-driving…
Apr 17
