This is a basic script for connecting U-Blox GPS to U-Center through an APM (as a middleman) basicly connects Serial 1 directly to Serial 0 (USB) bidirectionally, FYI you can modify the code to use the telemetry port Serial 3 as well.
This may be used to diagnose the ublox, or to configure it for APM.
You may need to adjust serial baud rates to match the hardware.
(for example a brand new ublox has a serial port rate of 9600, but APM wants it to be 38400.)
As an update to this, I restarted my efforts to have enhanced ublox support over the APM. I updated the CLI test in current SVN to support bi-directional Ucenter full access to the Ublox including its config over the Telemetry port. So either using xbees ( I like wireless myself ) or a ftdi cable attached to the telemetry port.  Here are some screen shots.
One thing to note, is (and ill figure out why later) I had to add baud rates to my APM_Config.h as it seems they are not getting passed into test.pde correctly at the moment.
As a Side Effect so to speak, HappyKillmore's GCS is able to read the ublox binary protocol stream wonderfully.
Another Action Shot of APM sending HK GCS using MAVLINK; over XBEE 900pro, and RVOSD sending 5.8ghz video to HKGCS.
This is excellent - tested and works great
thanks for posting this
Al
