  • :) no special name for the board. It is sold already together as one unit with the HC SR04.
    At the moment I saw on on EBay
    ----> http://www.ebay.com/itm/APM2-Ultrasonic-Module-HC-SR04-for-RC-APM-2...
    here you have the two boards together an the 3 pin analogue signal for APM and Pixhawk ;)
    Angelica Crespo said:
    Thank you so much, Bernardo! May I know the name of the additional board attached to the Sonar? What is it called?
    Bernardo said:
    Hi Angelica,
    the APM, Pixhawk, Pixhack, CUAV and similar FC from this series needs a special signal that is provided through
    a small additional board attached to the Sonar you have.
    It is available from RC stores, China suppliers and from EBay as a set..
    Please see the attached images.
  • Thank you so much, Bernardo! May I know the name of the additional board attached to the Sonar? What is it called?
    Bernardo said:
    Hi Angelica,
  • ..........more pics:  hope this helps a little :)
  • Hi Angelica,
  • Hi Bernardo, I'm using the same sonar sensor, HC-SR04. However, it has 4 pins: Supply, Trigger, Echo, Gnd. You mentioned that you used the sonar with the second board attached where 3 pins come out. May I know the details about this second board? I can't seem to make the 4-pin sensor work with Pixhawk. Any suggestions? Thanks!
    Bernardo said:
    Hi :)
    cool that the sonar works on APM.
    What is the A1 pin for the Pixhawk??
    I'm reading through the WiKi but there is no mention how to connect the HC-SRo4 to the Pixhawk.
    I use the sonar with the second board attached where 3 pins come out.
    The sonar shows a red led but no numbers in MP. I connect to the ADC 3.3 V plug in the middle.
    Is that ok?
  • trying the same with hcsr04 and apm 2.52 is there a known work around yet? any advice on how to hook up the 4 pin sensor would be greatly appreciated
  • Hi Bernardo,
    I also want to connect HC_SR04 with Pixhawk.
    The HC-SR04 that I have has 4 pins : 5V Supply, Trigger pulse Input, Echo pulse output, Ground.
    Can you please help me understand how I can connect this with pixhawk?
    Did you make any changes in ardupilot or HC_SR04 driver's code also to make it work?
  • Hi :)
    ok, today i can inform that the module works now!
    Pin 14 did it.
    Many thanks to Juan - you lead me to success :D
    (YAY!!! ) :D
  • sorry - I have trouble connecting to this forum, veeeeery slow and the html mode (menue does not show up) and also the upload-browse option is not there (pics) ?????
    It's only me ?
    • today it's normal again ,  quick connection to the DIY forum :)  - perhaps issues in DE 'cause of the rainstorms .....
DIY Drones via Twitter
Using ArduRover with an RTK GPS https://ift.tt/2N9I3RO
13 hours ago
23 hours ago
DIY Robocars via Twitter
23 hours ago
Friday
Friday
Thursday
RT @Heavy02011: @diyrobocars : A Home-brew computer club* for Connected Autonomous Driving on Jan 23rd, 2021 https://www.meetup.com/Connected-Autonomous-Driving/events/275728684/ #Meetu…
Thursday
Thursday
David Hori liked Isabella Domi's profile
Jan 12
RT @Heavy02011: ⁦@diyrobocars⁩ Autonomous Driving Assembly at #rC3. join us at https://rc3.world/rc3/assembly/diyrobocars-f1tenth/ ⁦@f1tenth⁩ ⁦@DAVGtech⁩ ⁦@DWalmroth⁩…
Jan 11
RT @chr1sa: New car designs coming for our next @DIYRobocars @donkey_car virtual race on the 23rd. Choose any one you want at race time Le…
Jan 11
RT @RoboticMasters: Thanks to @EllerbachMaxime and the Sydney Uni Capstone Students the @donkey_car @diyrobocars simulator is getting a ma…
Jan 11
Jan 6
Dec 28, 2020
An interesting line-following simulator to use with with your robocars: https://github.com/ron-grant/LFS
Dec 23, 2020
Dec 23, 2020
