hi,
i have this 4 pin sensor ar home
, and i was wondering if it can be used in complement or instead the classic sensor.
Anybody succeed using these object avoidance?
anybody tried?
 thx for your time
Hi Bernardo, I'm using the same sonar sensor, HC-SR04. However, it has 4 pins: Supply, Trigger, Echo, Gnd. You mentioned that you used the sonar with the second board attached where 3 pins come out. May I know the details about this second board? I can't seem to make the 4-pin sensor work with Pixhawk. Any suggestions? Thanks!
Bernardo said:
Hi :)
cool that the sonar works on APM.
What is the A1 pin for the Pixhawk??
I'm reading through the WiKi but there is no mention how to connect the HC-SRo4 to the Pixhawk.
I use the sonar with the second board attached where 3 pins come out.
The sonar shows a red led but no numbers in MP. I connect to the ADC 3.3 V plug in the middle.
Is that ok?
Hi Angelica,
the APM, Pixhawk, Pixhack, CUAV and similar FC from this series needs a special signal that is provided through
a small additional board attached to the Sonar you have.
It is available from RC stores, China suppliers and from EBay as a set..
Please see the attached images.
..........more pics:  hope this helps a little :)
Thank you so much, Bernardo! May I know the name of the additional board attached to the Sonar? What is it called?
Bernardo said:
Hi Angelica,
:) no special name for the board. It is sold already together as one unit with the HC SR04.
At the moment I saw on on EBay
----> http://www.ebay.com/itm/APM2-Ultrasonic-Module-HC-SR04-for-RC-APM-2...
here you have the two boards together an the 3 pin analogue signal for APM and Pixhawk ;)
Bernardo said:
Hi Angelica,
