Hello Everyone - HELP NEEDED
Last week my quad got stuck up a tree and in the process of getting it down (with a 60 foot pole) I lost the IMU.
I have fitted a new one and 3 days in, my grandson has pulled at the serial lead and ripped the USB connector away from the board - WHAT NEXT.....
I have managed to solder flying leads to four of the contacts left on the PCB but the center connection was ripped away from the board leaving me to solder to the track. This wasn't entirely successful as it will only work if I put pressure on the connection.
Can anyone tell me where the track goes to. All I can see it that it disappears under an IC.
If I can identify the other end of the track, I should be able to connect to make the connection.
If I can get it working, having a flying USB socket isn't a bad option as it strains the socket each time I connect to it.
Philip
I'm not sure which pin you mean, so i'v added a picture of the board eagle files
