Using AUX pins as relays for CHDK
I'm confused and a bit frustrated, would appreciate any help as I'm not sure how to proceed.
Setup: I have a pixhawk autopilot running Arduplane 2.77, using Mission Planner 1.2.95
I've been following this guide to get my CHDK enabled camera working with my pixhawk. I'm interested in getting the camera triggering based on distance traveled.
Obviously the guide was written with APM in mind, so it needs to be adapted a bit for pixhawk; specifically the setting for RELAY_PIN. I've kept the rest of the settings the same as in the tutorial.
Pixhawk has 6 AUX ports according to the quick start guide, I am assuming that the numbers above the pins correspond to the AUX port numbering. When you mouse over the RELAY_PIN parameter, it says that pin 54 corresponds to Pixhawk FMU AUX1.
Tried setting RELAY_PIN to 54, no joy. Did a bit more looking, discovered in the release notes for 2.77:
"Improved relay code
The relay and servo set code has had a major overhaul, with up to 4 relays now supported for MAVLink control and much better support for the DO_SET_SERVO, DO_SET_RELAY, DO_REPEAT_SERVO and DO_REPEAT_RELAY MAVLink commands. Along with these changes is a new parameter BRD_PWM_COUNT which allows you to specify how many auxillary PWM outputs to enable, with the remaining outputs being available as digital relays. This allows you to re-assign some of the aux servo outputs on Pixhawk for use as relays, by setting the RELAY_PIN, RELAY_PIN2, RELAY_PIN3 and RELAY_PIN4 parameters. The pin numbers for these pins start at 50 for the first aux servo pin, and go to 55 on Pixhawk."
Additionally,I found this github issue about this same problem that states that the Pixhawk can't trigger CHDK because its relay pins operate at 3.3V instead of 5V.
So i suppose my specific questions are:
1) Is AUX1 pin 50 or 54?
2) Can anyone confirm that the relays, when working properly, won't be able to trigger CHDK?
  • hi friend,     i am having problem with interfacing a relay module with apm 2.6 , i have tried lot of things but i am not sure that i have done it exact or what,.  so i'll very helpful to me if u can rectify my problem.. with  suitable guidlines.  thanks
  • Thanks Hugues, It's works great in my Sony Ilce 6000
    Hugues said:
    Here now the correct circuit to trigger a Sony Alpha 5000 with one transistor (tested succesfully by configuring one of the Aux port as a relay):
    3702059444?profile=original(This is real live diy !)
  • Hi all,
    I just want to say that I tried the Marco's circuit and worked OK on my Pixhawk to trigger a Canon S110.
    My settings:
    - 5V BEC connected to AUX pin 4 (RC12)
    - Servo cable to circuit Input: connected to AUX pin 5 (RC13)
    BRD_PWM_COUNT: 4
    - RELAY_PIN: 54
    - CAM_TRIGG_TYPE:1
    CAM_DURATION: 10 (1 sec)
    CAM_TRIGG_DIST: 0. Click "trigger camera now" in Flight Data and worked OK!
    Thanks!
    Max
  • Depending your model of Pixhawk, you have only servo output on the first 4 aux channels. Take a look at my posts yesterday.
    I'm using aux 5, relay signal, relay id'd as that on aux 5, 1tenth secont pulse andim taking 5 v power off the receiver to the main out bus...easy setup once I figured out the transistor EBC order.
  • I just got a Canon S100 - is Marco's circuit still the best DIY solution?
    I have a BC548 in my parts - could I use that instead of a BC547?
    I will have to order the BC557.
    Cheers,
    Sandy
    • At the low voltages involved ( 5V or less ) either transistor will work fine.  If you don't want to wait for a BC557 to arrive,  then the single transistor circuit shown <at this link> will work with your S100.
      • Will this design work if I place the transistor on the incoming voltage to the camera rather than the outgoing?3702718044?profile=original
        • I don't believe that will work as your have drawn it.   All of the circuits published so far depend on you driving the transistor into saturation ( Collector to Emitter voltage drop approaching 0v) by driving enough current into the base.  That won't happen with your circuit so the highest voltage the USB + signal will likely see is 3.3/2 = 1.65V.
          I could be wrong, allthough I'm quite sure that I'm not.  Build it and see?
          Why do you want to not use the original circuit ?
          • Just tinkering, it didn't work for the record!
            I could see 5v coming into the circuit, but when I multimeter across the usb plug it has a constant 0.26v and when I use "trigger camera now" command it would jump to 0.40-50v but the camera would not take a photo.
            I'll build the original and see how that goes.
DIY Drones via Twitter
RT @chr1sa: My talk on PX4 and FAA certification is coming up at 1:45 PST today on the PX4 Dev Summit livestream. Includes some cool new st…
Tuesday
RT @seesharp: I'm tuned into the PX4 / Dronecode free live conference. Great stuff. Microsoft AirSim talk in 10 minutes. https://t.co/0zbZ2…
Monday
DIY Robocars via Twitter
RT @masato_ka: 距離センサを3つとESP32を付けたラジコンカーをDonkeyCarライクにNNで自動走行。3層FC極小モデルをTensorFlow Lite for microcontrollerで動かしてる。機体は借り物でRumiCarって言います。Tenso…
Monday
RT @SmallpixelCar: My car was able to go all the way autonomously until the crosswalk. It was only 100 yards from the target. What should b…
Saturday
Liam left a comment on Agricultural UAVs
"Hi
I'm Liam from T-MOTOR. I would like to reach out to see if there is any possibility for us to work together.
We are a propulsion system manufacturer who offers motors, propellers and ESCs for all kinds of drone applications which vary from secur…"
RT @SmallpixelCar: Smart move. The car used the shadow to guide it through the bridge. This was never in the training samples. But it learn…
RT @SmallpixelCar: Getting closer to the target. Single camera. Untrained road. https://t.co/Wsr7RwDamj
Jun 29
Richard Cox left a comment on Australia
"Anyone in the DIYDRONES Australian subgroup based in Alice Springs, NT?
I am experimenting with Ardupilot (standard Arduplane), Pixhawk 4 FC in a 4-ch
RC "AXN Floater Jet" foamy plane..."
Jun 29
Omar Sykes left a comment on Australia
"Hi everyone, I am looking for someone who is good at drone building, repair and software in Adelaide. Please give me a call on 0477 319 219."
Jun 29
RT @RoboticMasters: #donkeycar https://t.co/czuLoVRcA4
Jun 29
https://t.co/DKQbNTbz0g
Jun 29
RT @RoboticMasters: Donkey car, car car car car car car; Donkey car, car car car car car car; Donkey Car. Anyone like our tiny tiny donkey…
Jun 29
RT @SmallpixelCar: After improving DBSCAN speed, I can get 11 frame per second on @NVIDIAEmbedded Jerson Xavier MAXN mode and the autonomou…
Jun 26
RT @Heavy02011: Join us at next Virtual Race League: ⁦@diyrobocars⁩ Race #4 - Parking Lot Nerds, August 1st https://t.co/5KUpu7VGaH
Jun 25
RT @SmallpixelCar: #CUDA implementation should be easy, because most of the time is on distance calculations berween two points and if the…
Jun 25
RT @SmallpixelCar: This is the view from the car. Even my lanenet inference is fast on @NVIDIAEmbedded Jerson Xavier, DBSCAN clustering tak…
Jun 25
