Variable Pitch TriCopter Flies !
Hi Folks
I have been building a variable pitch tricopter and wanted to share my results so far.
Basically - I chose a tri and not a quad, because the tri geometry is the same as a traditional heli 120 deg swash plate. Since I can't write a firmware on my own, I wanted to use an off the self solution.
I used a home made simple frame
3 e-flite park 370 hollow shaft motors with their variable pitch props
3 castle ESCs that I had laying around.
Here is a picture of the motor and blades on rear arm
Al
  • Here is a video of the tri on a table
    https://www.youtube.com/watch?v=XI_8KCJyjcA
    Al
  • Here is a list of my various attempts
    1 - radio programed as 120 deg swash and used airplane stabilizer - worked but not great
    2 - used a commercial heli flybarless system - it flew , but could not set gains low enough
    3- used my ardupilot mega - with traditional heli firmware - worked, but could not remove oscillations
    4- I retried the APM with heli firmware and reduced the swash upper and lower limits to 1400 to 1550 and lowered rate p to 0.8 and stabilize p to 3.5 no I term and stabilize D of 0,07
     This allowed me to fly and hover, but very touchy
    Check out the video - and now I need suggestions .
    http://youtu.be/xz1iJRmywms
    I think one point is I need to redesign the pitch servo so that I use more of the servo throw, but mechanically reduce the movement - I have lost alot of resolution using such a narrow pitch range in mission planner
    suggestions welcome
    Al
DIY Robocars via Twitter
RT @_JonMyer: 🏎 We need your help in naming my #AWS DeepRacer Underground Track 🏎 @davidfsmith's track is going to be referred to as 𝗔𝗪𝗦 𝗗…
15 hours ago
RT @gclue_akira: 仕事もおわったし、電脳化にとらい #マリオカートハック https://t.co/4IU90hCLgm
15 hours ago
This is the hashtag to follow all the people in Japan who are hacking the new Nintendo Mario Kart with the real AR… https://twitter.com/i/web/status/1319281354664677376
15 hours ago
RT @gclue_akira: @chr1sa @diyrobocars jupyter mario https://t.co/P0oHdjlCRq
15 hours ago
RT @_JonMyer: 🚨Our 1st AWS DeepRacer Community Race is Underway on http://twitch.tv/aws 🚨 Join us to find out which member of your commu…
Tuesday
Monday
RT @BackyardRobotcs: After an admittedly long wait, the new Tinymovr R3.3 motor controller is now available https://tinymovr.com 🥳
Monday
RT @_JonMyer: 🏎 1 hr left before the #AWS #DeepRacer Community 🏎 Top 5 Race tomorrow LIVE on Twitch 1st Place = $50 Amazon GC or AWS Credit…
Monday
Oct 16
Oct 15
Oct 14
RT @davidfsmith: Race virtually with The AWS DeepRacer Community Race and then join us on the track to see how your times compare on the ph…
Oct 14
Oct 14
Hiroki Tanaka liked Hiroki Tanaka's profile
Oct 13
RT @breadcentric: It's now!
Oct 13
RT @SahikaGenc: Happy Prime Day! AWS DeepRacer is available at a 30% discount today! @sunilmallya #AWSDeepRacer https://www.amazon.com/AWS-DeepRacer-Fully-autonomous-developers/dp/B07JMHRKQG/ref=sr_1_5?dchild=1&keywords=deepracer&qid=1602609599&sr=8-5
Oct 13
