Very strange behaviour for Quad
I took my quad out this morning to try various flight modes.  Alt hold was perfect (more or less without sonar), but when i swapped back to stablise I lost all throttle control and it went off on its own.  I could still control the direction, but that was all.
With the throttle, it would not respond even with full throttle.  I managed to get it back to where I was and attempted to land - but nothing.  It did come back down near the ground, even landing but I couldn't cut the motors.  I had to flick between the different modes to get the motors to stop.
I'm pulling the video together now.  However, looking at the logs and google earth, it appears to have gone through many modes [some of which weren't programmed].  I'm still going through the logs, but it would be great if someone else could have a look and let me know what they think.
2012-12-23 09-01 59.log
    Hi John and others, it appears [if I can read the logs right] that I was indeed flying in RTL.  What I don't get though is that I read that you can only arm the quad in stablise?
    I doubled checked my config and yes, it was possible to be flying in RTL mode as I had my configuration flipped, but that's how it would have been armed too.
    But would this explain the google earth differences too?  I swapped modes twice.  Once from stablise [or what I thought was stablise] to alt.hold and then back.  Yet google earth has many more changes than that.
    Thanks for the input from everyone and again, I get to learn something without any damage.  You'll never get bored with cutting edge technology. (;
  • Hi David
    I haven't checked your log yet as I am not on my computer at this, however, if you check into my posts, you will see that I have had an experience with my hexa (apm2.5) where the motors wouldn't shut down. You can see in the log some strange behaviour at the end of the flight, where I had to switch modes to get the motors to shut down. The thottle output was not responding to my stick input. While in flight at about 1 meter, it quickly pitched back and acted strangely as if it had switched modes.
    I will check your log as soon as I get a chance.
    Cheers, Steve
  • T3
    Did you check and make sure GeoFence is not turned on?
    Update:  I've attached the video to demonstrate the action and the fight to then bring it to the ground.
    23 December 2012
    There is also this video from a week ago - no changes to configuration have occured.
    16 December 2012
    Sounds like your CH3 channel became disconnected. Check your wiring?
DIY Robocars via Twitter
RT @SahikaGenc: AWS DeepRacer & Hot Wheels Track https://youtu.be/4H0Ei07RdR4 via @YouTube
Monday
Sep 8
RT @davsca1: We are releasing the code of our Fisher Information Field, the first dedicated map for perception-aware planning that is >10x…
Sep 8
RT @SmallpixelCar: How this works: 1)object detection to find cones in single camera image, 30 frames/sec on @NVIDIAEmbedded Xavier. 2)comp…
Sep 8
RT @SmallpixelCar: Use two color cones to guide the robocar. No map needed, on onsite training needed. Just place the cones and it will fol…
Sep 7
Sep 7
RT @roboton_io: Great to see http://roboton.io running at 60fps on the cheapest #chromebook we could find! #edtech #robotics #educat…
Sep 3
RT @openmvcam: Crazy in-depth article about using the OpenMV Cam for Astrophotography: https://github.com/frank26080115/OpemMV-Astrophotography-Gear https://t.co/BPoK9QDEwS
Sep 3
RT @openmvcam: Hi folks, it's finally here! Our first draft of our Arduino Interface Library is out! It works over SoftwareSerial, Hardware…
Sep 3
RT @chr1sa: Please let them have an open API. This would be perfect for @DIYRobocars races https://twitter.com/NintendoAmerica/status/1301513099707658246
Sep 3
RT @SmallpixelCar: Lanenet pretty much used all my GPU power on @NVIDIAEmbedded Xavier since I optimized with tensorRT. I need to run anoth…
Sep 3
xemone liked Max Gilson's profile
Aug 31
RT @LyftLevel5: Our @kaggle competition on Motion Prediction for Autonomous Vehicles is now live! Experiment with the largest-ever self-dri…
Aug 24
RT @chr1sa: Our next @DIYRobocars virtual AI car race will be on Sept 26th. Sign up here https://www.meetup.com/DIYRobocars/events/272786977/ https://t.co/UENKGSOWO8
Aug 24
New ready-to-run @NVIDIAEmbedded JetRacer car from Waveshare. Perfect for the next @diyrobocars race as soon as we… https://twitter.com/i/web/status/1297960223013867520
Aug 24
DIY Drones via Twitter
RT @chr1sa: The US government just approved 5 US-made drones for purchase, all based on the @Dronecode @PX4Autopilot standard. Great news f…
Aug 20
