Voltage divider help
First of all sorry for my bad english.. I have 10000mah multistar lipo and Attopilot 180A. I am connecting lipo to hexa, Mission planner batery monitor divider 15v. Is ıt correct.. APM forum say 10.1 for pixhawk. I can manuel change to 10.1 but pixhawk buzzer warnings and Battey voltage changes automotic on battery monitor.   What is the problem. Thanks
  • Thanks for reply. First, I manualy measured lipo voltage (24.8) then I connected lipo to hexa attopilot and I opened mission planner batery monitör via telemetry. I have select other sensor and wrote 24,8 on measured battery voltage. I select voltage divider . I changed 15v to 10,1. Buzzer alarmed and measured voltage automotic change low value. Again I changed 15v divider, it is normaly. Buzzer stop and measured voltage 24v. I dont understand. What happened.
    • If you are setting the voltage manually then the voltage divider will automatically update. You dont need to change it back to 10.1. My understanding is that you EITHER change the voltage manually OR the Voltage Divider Manually. Changing both is not the correct approach because they are both directly related.
      But again - let someone else confirm this too.
  • I believe that if the voltage indicated in mission planner is incorrect then you need to adjust that value manually such that the voltage in mission planner matches the actual voltage measured by an external device (multimeter).
    I don't think there is any standard number that will work for all. Depending on the current / voltage sensor used the value may differ.
    Atleast thats what I have understood... But Im no expert.
DIY Robocars via Twitter
RT @SahikaGenc: AWS DeepRacer & Hot Wheels Track https://youtu.be/4H0Ei07RdR4 via @YouTube
Monday
Sep 8
RT @davsca1: We are releasing the code of our Fisher Information Field, the first dedicated map for perception-aware planning that is >10x…
Sep 8
RT @SmallpixelCar: How this works: 1)object detection to find cones in single camera image, 30 frames/sec on @NVIDIAEmbedded Xavier. 2)comp…
Sep 8
RT @SmallpixelCar: Use two color cones to guide the robocar. No map needed, on onsite training needed. Just place the cones and it will fol…
Sep 7
Sep 7
RT @roboton_io: Great to see http://roboton.io running at 60fps on the cheapest #chromebook we could find! #edtech #robotics #educat…
Sep 3
RT @openmvcam: Crazy in-depth article about using the OpenMV Cam for Astrophotography: https://github.com/frank26080115/OpemMV-Astrophotography-Gear https://t.co/BPoK9QDEwS
Sep 3
RT @openmvcam: Hi folks, it's finally here! Our first draft of our Arduino Interface Library is out! It works over SoftwareSerial, Hardware…
Sep 3
RT @chr1sa: Please let them have an open API. This would be perfect for @DIYRobocars races https://twitter.com/NintendoAmerica/status/1301513099707658246
Sep 3
RT @SmallpixelCar: Lanenet pretty much used all my GPU power on @NVIDIAEmbedded Xavier since I optimized with tensorRT. I need to run anoth…
Sep 3
xemone liked Max Gilson's profile
Aug 31
RT @LyftLevel5: Our @kaggle competition on Motion Prediction for Autonomous Vehicles is now live! Experiment with the largest-ever self-dri…
Aug 24
RT @chr1sa: Our next @DIYRobocars virtual AI car race will be on Sept 26th. Sign up here https://www.meetup.com/DIYRobocars/events/272786977/ https://t.co/UENKGSOWO8
Aug 24
New ready-to-run @NVIDIAEmbedded JetRacer car from Waveshare. Perfect for the next @diyrobocars race as soon as we… https://twitter.com/i/web/status/1297960223013867520
Aug 24
DIY Drones via Twitter
RT @chr1sa: The US government just approved 5 US-made drones for purchase, all based on the @Dronecode @PX4Autopilot standard. Great news f…
Aug 20
