Voltage divider help
First of all sorry for my bad english.. I have 10000mah multistar lipo and Attopilot 180A. I am connecting lipo to hexa, Mission planner batery monitor divider 15v. Is ıt correct.. APM forum say 10.1 for pixhawk. I can manuel change to 10.1 but pixhawk buzzer warnings and Battey voltage changes automotic on battery monitor.   What is the problem. Thanks
  • Thanks for reply. First, I manualy measured lipo voltage (24.8) then I connected lipo to hexa attopilot and I opened mission planner batery monitör via telemetry. I have select other sensor and wrote 24,8 on measured battery voltage. I select voltage divider . I changed 15v to 10,1. Buzzer alarmed and measured voltage automotic change low value. Again I changed 15v divider, it is normaly. Buzzer stop and measured voltage 24v. I dont understand. What happened.
    • If you are setting the voltage manually then the voltage divider will automatically update. You dont need to change it back to 10.1. My understanding is that you EITHER change the voltage manually OR the Voltage Divider Manually. Changing both is not the correct approach because they are both directly related.
      But again - let someone else confirm this too.
  • I believe that if the voltage indicated in mission planner is incorrect then you need to adjust that value manually such that the voltage in mission planner matches the actual voltage measured by an external device (multimeter).
    I don't think there is any standard number that will work for all. Depending on the current / voltage sensor used the value may differ.
    Atleast thats what I have understood... But Im no expert.
DIY Robocars via Twitter
Oct 23
RT @_JonMyer: 🏎 We need your help in naming my #AWS DeepRacer Underground Track 🏎 @davidfsmith's track is going to be referred to as 𝗔𝗪𝗦 𝗗…
Oct 22
RT @gclue_akira: 仕事もおわったし、電脳化にとらい #マリオカートハック https://t.co/4IU90hCLgm
Oct 22
This is the hashtag to follow all the people in Japan who are hacking the new Nintendo Mario Kart with the real AR… https://twitter.com/i/web/status/1319281354664677376
Oct 22
RT @gclue_akira: @chr1sa @diyrobocars jupyter mario https://t.co/P0oHdjlCRq
Oct 22
RT @_JonMyer: 🚨Our 1st AWS DeepRacer Community Race is Underway on http://twitch.tv/aws 🚨 Join us to find out which member of your commu…
Oct 20
Oct 19
RT @BackyardRobotcs: After an admittedly long wait, the new Tinymovr R3.3 motor controller is now available https://tinymovr.com 🥳
Oct 19
RT @_JonMyer: 🏎 1 hr left before the #AWS #DeepRacer Community 🏎 Top 5 Race tomorrow LIVE on Twitch 1st Place = $50 Amazon GC or AWS Credit…
Oct 19
Oct 16
Oct 15
Oct 14
RT @davidfsmith: Race virtually with The AWS DeepRacer Community Race and then join us on the track to see how your times compare on the ph…
Oct 14
Oct 14
Hiroki Tanaka liked Hiroki Tanaka's profile
Oct 13
RT @breadcentric: It's now!
Oct 13
