I'd post on the Ardupilot.org forums. That's too technical for here
@Laser
look at [100%] lines
and verify dependencies manually, unpacking firmware to another target drive
creating directory
cannot create
are clear shell messages for you to check the directory tree manually
I've been trying to change permissions the /bin/sh file,but this does not solve the problem.
d j said:
@Laser
creating directory
cannot create
ok, just create missing directory CLI manually
and run installer once again
Which one of the missing directory?Can you elaborate on step?
thanks
There is a single directory missing , line starting with [100%] ( read my above reply)
look at your screenshot above:
generating
creating
cannot create
what comes next is follow-up to the above bug
use your preferred CLI editor and just
mdir (name of directory copied from screenshot)
