WPNAV parameters changed to 0 after autotune??
I just did an autotune and was scanning the full list of parameters after and noticed that some of the WPNAV parameters got changed to 0. I'm not sure if they were like this before but it doesn't seem they should be 0.
Also it's impossible to scroll down completely to see the last item but it's WPNAV_SPEED_UP I believe. I haven't flown waypoints in a few months but remember tweaking these settings such as slow up and slow down.
http://copter.ardupilot.com/wiki/arducopter-parameters/#loiter_horizontal_maximum_speed_wpnav_loit_speed
3691264693?profile=original
3691264774?profile=original
  • How can I see this data in the TLogs? I opened one in APM Planner but don't see where these parameters are. Tried opening in textedit but got this:
    n(3’.ò˛◊2æWPNAV_SPEED lœ(3’.üÿ˛ÿ2øWPNAV_RADIUS Ö0(3’0I†˛Ÿ2¿WPNAV_SPEED_UP pô(3’0a˛⁄2¡WPNAV_SPEED_DN P¥(3’0d¯˛€2¬WPNAV_LOIT_SPEED ∏#(3’2®˛‹»B2√WPNAV_ACCEL ®](3’2.˛›»B2ƒWPNAV_ACCEL_Z ès(3’25–˛fizD2≈WPNAV_LOIT_JERK
    • open in APM planners's Graph view, then |look in the grid - it's not always in tlog, depends of when you booted, whatever APM planner already had the parameters loaded.   so dataflashlog is better that way
      • I tried that but only had data flash logs from the previous month and they all showed the same data so this wasn't changed by autotune.
        Where can I find what the default values should be for these WPNAV parameters?
        Now I think what might have happened. I've noticed before that sometimes all the parameters don't get loaded when connected via telemetry. If you then change one and press write then those zeros get written. Do you know if this is a known problem? Makes me wonder what others got changed to 0.
        • yes, I think you are right -  I don't think there are any logic to catch that.
          this could work in the other "simple" tuning views - but could not happen in full parameter view.
          one thing you could do to prevent this from happening, is to see if 100% or parameters are loaded before using those features, or click "read" if that's an option.
          • Yes I try to do that, or only make changes in full parameter view so I can make sure all values loaded before I make a change and write back. It would be good if there was a solution to this because making changes over a slow connection could cause this to happen and make a lot of parameters 0 without the user being aware. Maybe there could be a way to monitor this in APM Planner so that until it loads all the parameters fully, it will not allow a write to happen.
            • Already reported :) https://github.com/diydrones/apm_planner/issues/869
              • Andre, do you know what the default values are for these or where I can find?
                WPNAV_SPEED
                WPNAV_RADIUS
                WPNAV_SPEED_UP
                WPNAV_SPEED_DN
                WPNAV_LOIT_SPEED
                I know I could guess at the values but would like to get them nearby before I start trying them. Would be good if defaulted values were indicated like the range is indicated so we can see if anything is really off.
                • well, the proper/safest/best way to determine any strange changes you may have, and compare to what's default for your firmware would be:
                  -backup parameteres to .param file
                  -reset dataflash format (factory reset)
                  -compare with backup, import what you need
                  but to answer your question:
                  WPNAV_ACCEL,250
                  WPNAV_ACCEL_Z,100
                  WPNAV_LOIT_JERK,1000
                  WPNAV_LOIT_SPEED,1000
                  WPNAV_RADIUS,200
                  WPNAV_SPEED,650
                  WPNAV_SPEED_DN,150
                  WPNAV_SPEED_UP,250
                  • Thanks! I will make the backup and check it that way.
              • Thanks Andre!
DIY Robocars via Twitter
yesterday
RT @_JonMyer: 🏎 We need your help in naming my #AWS DeepRacer Underground Track 🏎 @davidfsmith's track is going to be referred to as 𝗔𝗪𝗦 𝗗…
Thursday
RT @gclue_akira: 仕事もおわったし、電脳化にとらい #マリオカートハック https://t.co/4IU90hCLgm
Thursday
This is the hashtag to follow all the people in Japan who are hacking the new Nintendo Mario Kart with the real AR… https://twitter.com/i/web/status/1319281354664677376
Thursday
RT @gclue_akira: @chr1sa @diyrobocars jupyter mario https://t.co/P0oHdjlCRq
Thursday
RT @_JonMyer: 🚨Our 1st AWS DeepRacer Community Race is Underway on http://twitch.tv/aws 🚨 Join us to find out which member of your commu…
Tuesday
Monday
RT @BackyardRobotcs: After an admittedly long wait, the new Tinymovr R3.3 motor controller is now available https://tinymovr.com 🥳
Monday
RT @_JonMyer: 🏎 1 hr left before the #AWS #DeepRacer Community 🏎 Top 5 Race tomorrow LIVE on Twitch 1st Place = $50 Amazon GC or AWS Credit…
Monday
Oct 16
Oct 15
Oct 14
RT @davidfsmith: Race virtually with The AWS DeepRacer Community Race and then join us on the track to see how your times compare on the ph…
Oct 14
Oct 14
Hiroki Tanaka liked Hiroki Tanaka's profile
Oct 13
RT @breadcentric: It's now!
Oct 13
