    If you need longer range and mesh support you can take a look at jDrones long-range telemetry. You can upload mesh software on these modems and it works 101% on them. Why?? Well Seppo/RFD who made these modems also helped to develop mesh software that we are talking in here.
    We also have custom pixhawk cables for the modems if you need.
    jD-RF900 Longrange telemetry set
    Long range telemetry set for all your UAV and UAS needs
    • Is there any information available (link) on the mesh network firmware for the rf900 radios?
  • no problem with any radio I am using now. setup the radio test it with terminal window on both xbee type text in both window should apare on opposing terminal window using a PC or MAC.
    • Alright. Thanks so much for the information. Can I get back to you if I need any more help?
      • sure!
  • hello,
    use series 2 2.4
    • After I set up the xbee by following the instructions. Do I have to program the qgroundcontrol or pixhawk?
      • radios are one time setup nothing to do on the FC side at all!
  • May I know what xbee model are you using. I'm bought the xbee series 2
  • info is here
    http://copter.ardupilot.com/wiki/xbee-radios/
gotham liked gotham's profile
yesterday
Hiroki Tanaka liked Hiroki Tanaka's profile
Oct 13
Derrick Davies liked lisa TDrones's profile
Sep 23
