Team-blacksheep have very nice frame for DJI-NAZA with some fancy PDB, but I don't have NAZA and I wanted some modification to mount APM2/2.5, so here is my version of that frame, no fancy PDB and PCBs, just black fiberglass :)
If you do have DJI NAZA go get that frame right NOW !
 APM2.0 with 90° pins fits under the top plate with analog and telemetry pins exposed.
APM2.5 with ublox GPS.
Set the LED_MODE parameter to 9, It will slow blink when disarmed, solid armed, fast blink + beep on low battery.
The CG and the APM location moved a little bit, but it can fly as regular X quad. (don't pull back too much)
I just changed the AP_MotorsQuad.cpp X frame set-up to:
add_motor(AP_MOTORS_MOT_1, 55, AP_MOTORS_MATRIX_MOTOR_CCW, AP_MOTORS_MOT_2, 1);
add_motor(AP_MOTORS_MOT_2, -125, AP_MOTORS_MATRIX_MOTOR_CCW, AP_MOTORS_MOT_1, 3);
add_motor(AP_MOTORS_MOT_3, -55, AP_MOTORS_MATRIX_MOTOR_CW, AP_MOTORS_MOT_4, 4);
add_motor(AP_MOTORS_MOT_4, 125, AP_MOTORS_MATRIX_MOTOR_CW, AP_MOTORS_MOT_3, 2);
Setup
Motors: Tiger MS2212-13 980KV
ESC: jDrones 18A (Flashed with SimonK FW)
I really like the 10X5 Graupner e-props (or new Carbon 10X5 e-props) with 4S 3000mah lipo, after some fine-tuning its very sharp fly.
Here some raw clips from Arducopter 2.8.1 tuning flights:
BTW Jani from jDrones (that where I CNC all my custom frames ;) ) has put together fancy RTF kit, so check that one out.
EDIT:
The top outside hols for the arms are ~0.5mm off, I think so chek it before cuting.
ARDU_DIS_APM25.DXF
Comment by Isaac Sloan on January 17, 2013 at 11:27pm
Nice job. I've been using the graupners on here with a 4S 6000mah and it still fly's really great. I just have the f450 normal frame though. What are the carbon props you were referring too?
Comment by Dmitry Che on January 17, 2013 at 11:41pm
Nice work - everything done very good! But I would say it is not necessary to make a hole in the top plate to make GPS works. From my experience fiberglass not a obstacle for this sensor. My copter have 2 GPS - AMP2.0 and Eagletree inside http://diydrones.com/photo/dsc05074 and http://diydrones.com/photo/my-new-project-flow working good!
Comment by Terry Brooks on January 18, 2013 at 2:09am
Would never give my hard earned cash to TBS
Comment by Crasher on January 18, 2013 at 2:13am
Very nice work Max!
I'd love to get the DXF files for this if you ever decide to open source it! I have the TBS Discovery, but would like to experiment with a symmetrical version as while it flies good, the assymetric layout has it's limitations performance wise.
Comment by Jason Wise on January 18, 2013 at 2:37am
Thanks for the ULN2803 wiring info
Comment by Max Levine on January 18, 2013 at 7:10am
@Crasher I added the DXF.
@Isaac jDrones should have them in stock soon.
@Dmitry I really like the Tilt mount that you made, I'll try it on my next build :)
Comment by Paul on January 18, 2013 at 7:28am
Nice work Max.
Once you've tuned it, would you mind sharing your param file?
Thx
Comment by zmooth on January 18, 2013 at 12:07pm
Interesting, thanks for sharing. It looks yours has slightly narrower angles and yet you get no props in gopros frame. Are you using the gopros narrow or wide setting ?
Comment by Kevin B on January 18, 2013 at 12:46pm
Nice job, and thanks for sharing the DXF. Are you going to try AC2.9? I'm curious how well 2.9 works with hard mounting.
Comment by Zachariah L Hanson on January 19, 2013 at 6:53pm
Looks good.  I too am working on a clone version of the TBS Discovery, only mine was a bought clone and Im using multiwii on the Flyduino Mega Board, GY-86, GPS, er9x flashed TX, SimonK flashed ESC, all my software is open source! My Quadcopter Build
Comment
