Team-blacksheep have very nice frame for DJI-NAZA with some fancy PDB, but I don't have NAZA and I wanted some modification to mount APM2/2.5, so here is my version of that frame, no fancy PDB and PCBs, just black fiberglass :)
If you do have DJI NAZA go get that frame right NOW !
 APM2.0 with 90° pins fits under the top plate with analog and telemetry pins exposed.
APM2.5 with ublox GPS.
Set the LED_MODE parameter to 9, It will slow blink when disarmed, solid armed, fast blink + beep on low battery.
The CG and the APM location moved a little bit, but it can fly as regular X quad. (don't pull back too much)
I just changed the AP_MotorsQuad.cpp X frame set-up to:
add_motor(AP_MOTORS_MOT_1, 55, AP_MOTORS_MATRIX_MOTOR_CCW, AP_MOTORS_MOT_2, 1);
add_motor(AP_MOTORS_MOT_2, -125, AP_MOTORS_MATRIX_MOTOR_CCW, AP_MOTORS_MOT_1, 3);
add_motor(AP_MOTORS_MOT_3, -55, AP_MOTORS_MATRIX_MOTOR_CW, AP_MOTORS_MOT_4, 4);
add_motor(AP_MOTORS_MOT_4, 125, AP_MOTORS_MATRIX_MOTOR_CW, AP_MOTORS_MOT_3, 2);
Setup
Motors: Tiger MS2212-13 980KV
ESC: jDrones 18A (Flashed with SimonK FW)
I really like the 10X5 Graupner e-props (or new Carbon 10X5 e-props) with 4S 3000mah lipo, after some fine-tuning its very sharp fly.
Here some raw clips from Arducopter 2.8.1 tuning flights:
BTW Jani from jDrones (that where I CNC all my custom frames ;) ) has put together fancy RTF kit, so check that one out.
EDIT:
The top outside hols for the arms are ~0.5mm off, I think so chek it before cuting.
ARDU_DIS_APM25.DXF
Comment by Bas Tijs on April 30, 2013 at 1:27pm
Love the modification Oyvind Amundsen made, I want one :)
Comment by Oyvind Amundsen on April 30, 2013 at 2:26pm
Thank you Bas Tijs
Here is my mod including the combined ESC mounts/Legs I have made.
I
n this image the tubes are 250mm long, I´m going to make them shorter - Next test I plan to try 190mm
I´ll try to share my files using skydrive:
ESC mount/Legs - Sketchup
https://skydrive.live.com/redir?resid=4640C2764D145450!931&authkey=!ALUZvBrcSZMm1z4
CP - dxf
https://skydrive.live.com/redir?resid=4640C2764D145450!932&authkey=!AJa3xtjJFsmZM6A
I´m working on a new frame based on this one, but with the motors in X quad position and 50cm motor - motor.
Comment by Oyvind Amundsen on April 30, 2013 at 2:27pm
Comment by Bas Tijs on April 30, 2013 at 2:39pm
Thanks for sharing! But I think the center plate points to the wrong file? (ESC_Legs_3.skp)
Comment by Oyvind Amundsen on April 30, 2013 at 2:44pm
Comment by Yves Gohy on April 30, 2013 at 11:34pm
Comment by Oyvind Amundsen on May 1, 2013 at 2:15am
Smart design Yves - I my try something like that on my next quad (do you share the dxf file?)
Comment by Bas Tijs on May 1, 2013 at 11:04am
Which thickness fiberglass plate did you use?
Comment by Yves Gohy on May 1, 2013 at 11:18am
I built with 2mm
Comment by Yves Gohy on May 1, 2013 at 11:19am
As soon as I finished I will share it, of course.
Comment
