Team-blacksheep have very nice frame for DJI-NAZA with some fancy PDB, but I don't have NAZA and I wanted some modification to mount APM2/2.5, so here is my version of that frame, no fancy PDB and PCBs, just black fiberglass :)
If you do have DJI NAZA go get that frame right NOW !
 APM2.0 with 90° pins fits under the top plate with analog and telemetry pins exposed.
APM2.5 with ublox GPS.
Set the LED_MODE parameter to 9, It will slow blink when disarmed, solid armed, fast blink + beep on low battery.
The CG and the APM location moved a little bit, but it can fly as regular X quad. (don't pull back too much)
I just changed the AP_MotorsQuad.cpp X frame set-up to:
add_motor(AP_MOTORS_MOT_1, 55, AP_MOTORS_MATRIX_MOTOR_CCW, AP_MOTORS_MOT_2, 1);
add_motor(AP_MOTORS_MOT_2, -125, AP_MOTORS_MATRIX_MOTOR_CCW, AP_MOTORS_MOT_1, 3);
add_motor(AP_MOTORS_MOT_3, -55, AP_MOTORS_MATRIX_MOTOR_CW, AP_MOTORS_MOT_4, 4);
add_motor(AP_MOTORS_MOT_4, 125, AP_MOTORS_MATRIX_MOTOR_CW, AP_MOTORS_MOT_3, 2);
Setup
Motors: Tiger MS2212-13 980KV
ESC: jDrones 18A (Flashed with SimonK FW)
I really like the 10X5 Graupner e-props (or new Carbon 10X5 e-props) with 4S 3000mah lipo, after some fine-tuning its very sharp fly.
Here some raw clips from Arducopter 2.8.1 tuning flights:
BTW Jani from jDrones (that where I CNC all my custom frames ;) ) has put together fancy RTF kit, so check that one out.
EDIT:
The top outside hols for the arms are ~0.5mm off, I think so chek it before cuting.
ARDU_DIS_APM25.DXF
Comment by Ray Hammond on June 17, 2013 at 3:11pm
The marks are on the bottom plate for C of G. There is a little leniency here though. It's set up for the cam to be on so you'll have to balance up once your set up is almost built. Your battery weight doesn't seem too bad so can't see there being an issue to be honest. I've extended the arms on mine and upped the power and battery size. Had to enlarge battery bay by 2mm to get the batt I want in. Ill play around at the front to balance things up later. I'd still put the APM where the naza marks are.
Comment by Cam Donaghey on July 1, 2013 at 7:37pm
Hello everyone. I was wondering if 1.5mm thick carbon sheet would be strong enough to use for a build or should I use 2mm?
Cheers.
Comment by David Ardis on November 3, 2013 at 11:12am
Just finished by TBS Style Discovery frame based on the DXF published earlier
TBS Style Discover Test Flight
David Ardis
Comment by idem2Lyon on November 28, 2013 at 3:43am
hey, which software are you using to make this scheme ? https://api.ning.com/files/mzLbifxKbCTiun7OSDPnnT-dix5HL*wpJynWItZtgWfknCCW14jIlsw76HmI6B1XJj9jfTR3Gq-q2FC9hBhVcXasuU8JEVQQ/leds01.jpg?width=700
Comment by Esteban on July 26, 2014 at 8:54am
Hi , where is the CG for this quad , i cant find it ?
Comment by Esteban on July 28, 2014 at 8:24am
Comment by dudz on January 18, 2015 at 11:33pm
What sort of flight times are you getting with 4S 3300 lipos on this design ?
I have always used the Chinese motors. Are the Tigers any better ?
Comment by dudz on January 18, 2015 at 11:34pm
I have got a couple of new 4S 3000's about somewhere. I might try this design
Comment
