The new design of the Mugin UAV 3M is out.
It's a huge UAV platform with 300 mm wingspan. The platform caters to larger UAS projects such as universities or commercial projects. It's really not a beginner platform.
The platform is available here: Mugin UAV 3m vIII
It comes with or without engine/prop.
Twin Motor
Type: Two-stroke piston valve petrol aircraft engine
Displacement: 55cc(27.2ccx2)
Bore x Stroke: 34mm×30mm
Carburettor: Walbro(Diaphragm & Butterfly Valve)
Max. Output: 5.6ps/7600rpm
RPM Range: 1600-7800rpm
Weight: About 1780g(Engine+muffler+CDI)
Ignition power: Auto advanced CDI(DC 4.8 Volts , 4 cell NiCad or NiMh battery)
Fuel mixture(Ratio of gasoline and oil): 25-40 : 1
Propeller: 20X12-23X8 two-blade prop( suggest to use 22x8 prop)
Comment by Andrew Tridgell on June 24, 2013 at 6:01am
@Eduardo, sorry email didn't get through - maybe got caught by our spam filter? You are welcome to join our mailing list, or just ask Stephen Dade, Jack Pittar or myself Qs here. Jack is the expert on the setup of our Mugin.
Cheers, Tridge
Comment by eduardo on June 24, 2013 at 6:47am
Thanks Andreew.
Here are my first blog post about MUGIN:
Here you can see the main gear attachment to fuselage, noose gear details, motor bay and some more ..
I will put construction details in the next post.
http://brquad.blogspot.com.br/
Comment by eduardo on June 24, 2013 at 10:35am
@Andrew, the camberra MUGIN is the version 1.
I look at mugin v3 and the wing is made all by wood.
The hinge use the ribbing terminal.
I think the the wing from v1 and v3 are different.
Comment by cessna1525 on June 24, 2013 at 11:41am
can anyone tell me the measurement of the payload bay of hugin 2 uav platform. thank you
Comment by eduardo on June 24, 2013 at 11:45am
This thread is about MUGIN my friend.
You will find this um rcgroups threa about HUGIN.
Comment by Paulino M. Lacap Jr. on June 24, 2013 at 6:06pm
My Mugin V3 has arrived and its a humongous plane. This will be able to carry multiple sensors and additional fuel tanks. I an thinking of using the SullivanUAV generators to sustain electric power. Has anyone tried this set before?
May I ask where I can buy spare 22X8 props. This is the first time I will fly a gasser this large.
Jerome Lacap
Philippines
Agricultural Monitoring team
Comment by Fernando K on June 24, 2013 at 6:28pm
eduardo,
Are you selling it? Do you sell only the frame? I'm in Brazil too. Please tell me how much do you want for the frame (if you sell only the frame) my e-mail is fernandokerst@gmail.com
Comment by Fernando K on June 24, 2013 at 6:30pm
btw, this was my first post here, I found this topic by looking the diydrones blog every day.
Admin
Comment by Morli on June 24, 2013 at 7:55pm
@Jerome ,
I purchased quite a few props of various config/size from hobbyking. 3 blade  pusher are little difficult to find but they are available there.
I have seen sullivan generators used in smaller airframe but am not aware of its performance. It was little bulky.
but there is one more choice called Jewel  onboard generators which is converted brushless  moto.  check that out.  I am trying to home brew this and looking for info on what modification is needed to make brushless motor/generator.
Comment by ECODRONES on June 24, 2013 at 9:26pm
Yes, are you absolutely right, Giovanni.
Impossible to compare Penguin B and Mugin (any version). Swan-02, I never see before, in fact.
My thoughts about Mugin V3, are concerning converting for EP.
Btw, I've talked with Fabio at mundogeo connect 2013. Very good plane / systems do you are building, congrats!
Comment
