Netflix joked about it, I thought I'd give it a try since my brother in law wanted to borrow one of my DVD's.  Here are the results.
Comment by AKRCGUY on October 19, 2014 at 9:43am
Euan, PM Sent.
Comment by BacklashRC on October 20, 2014 at 8:54am
Euan, my concern with your drop system is that the associated magnetic field may interfere with the functionality of the flight controller's magnetometer.  Have you noticed any adverse side effects, or have any recommendations for preventing such issues?
Comment by Euan Ramsay on October 20, 2014 at 9:37am
None whatsoever, and this was an priority test item.
Basically, the most likely time there will be a significant increase in magfield is doing the state changes. And these only last 0.3 seconds each. In steady state, magfield interference is negligible if you keep to the recommended 10cm of separation.
I am doing a "lite" version for phantoms, but I suspect we will start to see magfield issues there - the phantom compass is down on the leg, and will be only 2-3cm from the magnet.
Comment by Euan Ramsay on October 20, 2014 at 9:40am
As for recommendations - stick to the normal design parameters for a APM2.6 + Arducopter 3.x.x setup (ie good compass separation) and use a standard GPS pole, and it will be fine.
Comment by chrisa on October 21, 2014 at 8:05am
It seems like "the payloader" (just an electromagnet from a solenoid) is a waste of weight because of all the wires and magnets, and contraptions that need to be attached, and it only can carry 1kg, which is pathetic as far as delivery is concerned.
a $10 servo weighs 1/10th of that thing, or less, and can hold more than 1kg securely, just as a simple "door".
Using two servos would make an easy "grabber"
Comment by Euan Ramsay on October 21, 2014 at 8:30am
I'll gloss over your comments, partly because you're still bitter about the airframe comments, and because transparently you don't know the difference between an EM and an EPM. Maybe you should look it up on Wikipedia...
What you should have said is that the magfield intrusions would be massive, and would kill all yaw control in the copter. And mentioned the all inclusive weight of a comparable servo *system" is lighter and how it uses *less* wiring than the single 5V servo wire this system can. I'd love to see that.
Comment by Todd on October 21, 2014 at 6:08pm
Nice DVD delivery, neat.
Comment
